Magic Chef 9815 Electric Single Oven Logo
Anonymous Posted on Apr 16, 2010
How do i put the ignition part in my oven
I bougth the igntion bar because it was not heating my oven and now i dont remember how do i have to put it back
Anonymous
Level 3:
  • Magic Chef Master 43,501 Answers
  • Posted on Apr 16, 2010
Anonymous
Magic Chef Master
Level 3:
Answers
43501
Questions
0
Helped
10844069
Points
101584
Here is a tip that I wrote about that replacement...
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Oven heats up, but then turns off
either bad igniter or bad oven safety valve check with multi meter. for continuity. beware that the igniter can check ok with multi meter but still fail manually as it may not put out enough current to run heat and ignite flame. u may also have a bad oven sensor? which turns off heat prematurely agin check with multi meter
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 • Ovens
3helpful
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 • Ovens
4helpful
Replace igniter part # 1990 in oven of model #3627332192
It's usually pretty simple. Start by turning power off to the oven - unplug it or disconnect power at the circuit breaker. Open oven door, remove all racks, then remove oven floor panel (it might be secured with two bolts or clips on the back side). Remove the flame spreader (one nut). Now you have the oven burner and igniter exposed. If the new plug differs from the old, cut off the plug and use ceramic wire nuts (should be supplied with igniter) to connect the wires. Don't shake the igniter - the coil is very fragile. Once the igniter is replaced make sure the wires are connected securely. Put everything back the way it was and test the oven.
Below are the two most popular oven igniters: flat bar igniter and round igniter.
Flat igniter - this is by far the most commonly used oven igniter. Includes all necessary pieces to replace longer ceramics. Size: 3-3/4" long. Fits Maytag, Whirlpool, KitchenAid, Magic Chef, Tappan, Jenn Air, GE (flat bar only), Sears Kenmore (flat bar only), even some Thermador cooktops and Viking ovens. - ff693fe.jpeg
1helpful
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 • Ovens
2answers
Oven won't heat
Eliminate the gas valve first--Use a meter and connect the 2 wires off the valve to it.turn the oven on and you should either read 120v or 24v depending on the unit.If you have the voltage but no ignition the valve may be bad.However if you dont have the voltage i would suspect the heat board or thermostat as an issue.I would also check the pilot/burner for a clog from soot,even more so if the units propane.Let me know
30helpful
4answers
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Pilot heats up but gas will not come into bar with little holes in oven
Check the voltage at the oven gas valve, if you are getting 120v, then you have a bad gas valve.
Top Magic Chef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
