Lionel Cw 80 Transformer Logo
Question about Lionel Cw 80 Transformer
CW 80 -Direction button doesn't work
On my CW-80 the direction button does not work. I also noticed that when I move the orange control from 30% back to 0% I don't reverse directions no matter how many times I do it.
I also noticed that there is a problem where the transformer does not go to zero volts with the orange knob at zero position ( 3volts at Zero %), thus not allowing the forward neutral reverse function on the loco. This is a problem.
If I leave the orange knob at 30 % and pick up the loco off the track and touch the track several times the loco does a forward- neutral- reverse.
How can this be corrected?
Posted by rlenn on
edoptician
    New Friend:
  • 22 Answers
Recent Lionel transformers are notorious for their issues. Put an old fashioned reverse switch into the circuit, an old Lionel 88 will do the wire to terminal 1 of the lockon or the wire tothe center rail needs to be cut and attached to the 2 terminals of the 88 reverse switch. Note this is ancient technology from the 30s to 50s
Posted on May 08, 2019
5 Related Answers
bobkelsey
  • 46 Answers
SOURCE: WHISTLE STOPPED WORKING on CW-80
replace the button with a new one just remember which wire goes to which terminal. you will need a soldering iron and electronic solder to do this trick , also make sure you un plug the transformer. by any chance you got any n-scale trains you want to get rid of . If you do send me the info @ [email protected] I'am a disabled veteran with little funds.
Posted on Dec 01, 2008
Anonymous
SOURCE: lionel CW - 80 transformer
Check out this link, I think it will help.
http://www.lionel.com/media/servicedocuments/71-4198-251.pdf
Posted on Jan 20, 2009
condega5
  • 4 Answers
SOURCE: Can I use the cw-80 transformer on any Lionel
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Posted on Feb 10, 2011
Anonymous
  • 8197 Answers
SOURCE: how many feet can 1
If you are talking about how many feet of track than your answer is 50. You can get the manual on the link below.
Posted on Feb 19, 2011
Gerald Lewis
  • 34 Answers
SOURCE: My cw-80 Lionel transformer has
The CW-80 is not suited for electronic sound systems. The output is non-sinusoidal. When electronic sounds are generated for some locos, the sound will be garbled. Use another power source. The Z1000 MTH power source or similar is recommended as are many other older Lionel standard power xfmrs. For the sound stay on problem with switch off, try putting a fixed load on the tracks ie: An accessory of some kind (lights etc). Usually a fixed electrical load will fix this problem. Overall, I would recommend changing out the power source and save yourself a lot of headache..
Posted on Sep 05, 2011
Kodak carousel 650h will not advance or go back. Not mechanically jammed. Doesn't respond to buttons either on main housing or from remote. Select button, fan and lamp all ok.
If the select button functions correctly, then it sounds like you have a wire broken or a wire nut that holds a bundle of wires together has fallen off. If it was the solenoid link, then the Select function would not work. After removing the bottom cover, look for the orange wires, That is the cycle circuit. Look for a broken or unattached orange wire from the side button and the remote receptacle.
The other possibility is that the direction lever is stuck, bound up or the direction lever spring is broken. The attached image of the top plate of the slide change mechanism will show you the end of the direction lever. It should move freely, up & down on its center pivot. You should see a small, wire spring, about 2-3 inches long on the lever. If the spring is not there, or the lever does not move freely, that may be the cause of no forward or reverse.
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
1helpful
Hello. i would like to know the direction drive shaft spins looking from rear of bike cw ccw
If the drive shaft is on the right side of the bike it will spin counter clockwise (ccw) when the cycle is moving forward.
If the drive shaft is on the left side of the bike it will spin clockwise (cw) when the bike is moving forward.
Runs ccw needs to run cw hp 5 460 v hz60 wired motor for high volts last 3 wires are orange that went to no.2fc yellow went to no.3 black wire went to no.1
Look you are putting to much thought in to this. To reverse the direction of a 460 volt motor simply swap two of your power feed leads. You know the L1, L2, and L3 simply change L1 with L2 and your direction will change, calm down and do not over think this.
The man remodeling my bathroom says I received two left handles on my roman tub faucet..but I noticed the tiny small screw on each handle going in the same direction on each handle ..did he put it in...
No, he is right, the handles turn in opposite directions... the cold CW and the hot CCW... you cannot change the direction of the on/off sequence...and the rotation direction... so... yes you will need to send back the wrong one and get the right one or send back the whole set and get it replaced...
heatman101
Dec 09, 2010 • Delta Home
Machine rocks, all four sides, removed and oiled clutch bearings, tightened the belt, still rocks and errors out no matter the size load, machine is balanced. ?
I feel you still have a clutch problem... Did you try this test before you cleaned up and re-lubed the One-Way Roller clutches in the Clutch pulley?
From my Clutch Fix post;
Let's demystify dC and uC error codes plaguing the FAV6800A and the LCD Flavor FAV9800A
One last step before you clean up those pesky Clutch Pulley One-Way Roller Clutches/bearing.
Holding what I call the Spinner Shaft coupler first picture. Insert that coupler into the Clutch One-Way Roller bearing plate.
Now while holding the Spinner Shaft Coupler with one hand as I show in the second pic with your other hand rotate the white bearing plate in the CW direction around the Spinner Shaft Coupler.
The One-Way Roller Clutch bearing plate should rotate freely in the CW direction this is the wash/agitate direction.
Now rotate the One-Way Roller Clutch bearing plate in the CCW direction it should lock up solid.
Most times the One-Way Roller clutches will slip did it slip for you? This will cause the agitator shaft to move slightly causing slight tumbler rotation while the wash basket begins to spin up unbalancing the wash load causing big time wash tub swings and those pesky unbalance error codes.
The Control Board sees the TDS analog voltage swings out of design limit and shuts down the spin cycle. If the TDS was not working as designed the machine would walk across the room and unplug itself or self-destruct.
The Control Board programming will try several attempts to redistribute the wash load and when the magic number of wash load redistribution attempts has been reached the Control Board signals a dC or uC error code to the display. I believe the FAV9800A signals a text error to the display i.e. "unbalance condition?" or something like that.
Anyway I thought you might want a little more insight into just what is going on here. A very poor Clutch design by Maytag. Mine failed at the 3.5yr mark of service and I was not about to trash a $1K machine. Sorry to say I feel number of them do make it to the curb on bulk trash pickup day.
I call this the Spinner Shaft Coupler. Not sure what Maytag calls it.
This is the One-Way Roller Clutches/bearing.
While holding the Spinner Shaft Coupler with one hand rotate the white One-Way Roller Clutches/bearing plate in the CW Wash/Agitate direction with your other hand. It should rotate freely in the CW direction around Spinner Shaft Coupler.
Now rotate the white One-Way Roller Clutches/bearing plate in the CCW direction the Spin Cycle direction. It should lock up and not rotate CCW around the Spinner Shaft Coupler. If it does the tumblers will rotate slightly and cause the wash basket load to go off balance as the wash basket spins up.
If the TDS is working as designed the machine will fail in Spin Cycle with dC or uC error codes. If the One-Way Roller Clutches/bearing can be cleaned up and re-lubed you could be back in service with no cost.
If so what were the results?.................Rich
2answers
Spin cycle locks up
it is the clutch and be repalced fairly easily
TV one side slight blurr
hello, here some help with this
hope this help below are adjustments
and values
How to enter into Service Mode
While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
seconds.
10.1.1. Key command
"1" button...Main items Selection in forward direction
"2" button...Main items Selection in reverse direction
"3" button...Sub items Selection in forward direction
"4" button...Sub items Selection in reverse direction
"VOL" button...Value of sub items change in forward direction ( + ), in reverse direction
Value is shown as a hexadecimal number.
 ·Preset value differs depending on models.
 ·After entering the adjustment mode, take note of the value in each item before starting adjustment.
Main item Sub item Sample Data Remark
ADJUST CONTRAST 000
COLOR 3F
TINT 03
SUB-BRT 800
WB-ADJ R-CUT 80
G-CUT 80
B-CUT 80
R-DRV E6
G-DRV F0
B-DRV FC
ALL-CUT 80
ALL-DRV FC
OPTION BOOT ROM Factory Preset
STBY-SET 00
Emergency OFF
CLK MODE 00
CLOCK 000
AGING RGBW
COUNT
ALL WHITE
ALL RED
ALL GREEN
ALL BLUE
ON/OFF
RAMP WHITE
RAMP RED
RAMP GREEN
RAMP BLUE
1% WINDOW
COLOR BAR
A-ZONE B-ZONE/4 TRIO
SCROLL
WHITE FLAME
RM-SET CODE A Fixed
SRV-TOOL - See next
10.1.3. How to exit
Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control
good luck hope tis help.
1helpful
Top Lionel Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
