Replaced memory card and battery but that didnt solve the problem. unable to take photos
SOURCE: system error
Hi, my camera has been doing this for two years off and on, more often lately. I also found the lens sticking when vacationing somewhere warm and humid and tropical. I ususally fix it by gently pushing on the lens as I turn it off. It may take several times for the camera to correct itself. I found this website hoping to find a better solution to this problem, too, it sounds like the only solution is to upgrade to a new camera. Too bad, I love my 4300 and have been very happy with the photos taken. But, having a camera that can take 7mp and up is attractive and for the price of repairing this one. Hope this helps.
SOURCE: memory card locked!
There is alittle slide on the memory card.
Take it out. Look for it. Depending what you have it may be yellow, look on the left. If it's down, slide up and it will be unlocked. :)
SOURCE: Sony Cybershot DSC-P200 Get error message
have you tried formating the card and camera
to format the card insert itinto card reader and go to my computer right click on the drive then select format and follow the instructions this should solve the problem
also try reseting the unit at the same time by following the onscreen instructions in the set up mode
SOURCE: Memory Card Error after Formating memory card
instead of quick format, use the full format. Then put back in your camera and format again with the camera.
