Microsoft Xbox 360 Console Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keeps freezing after a few seconds of turning on. after freezing, turn off, and has 3 red rings
Anonymous
Level 2:
Sergeant:
  • Expert 209 Answers
  • Posted on Apr 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
209
Questions
0
Helped
34424
Points
619
Hello there!
That could be cooling problem of xbox 360. Check xbox360.com and what those lights suggest, thats some error mark im not sure but it also could be xbox360 cooler problem. Check website and you will know what to do next.
Sincerely
Aleksandar Adzic
The red light is blinking and when i turn it on it goes to green for a few seconds and then beeps and blinks red again.
You have "The red ring of death" If 1 corner is blinking: Turn it of and wait a few days for it to cool off. If 2 corners are blinking: Do the same, but check after 3-5 days to see if it works. If 3 corners are blinking: You HAVE to see a xbox repairer, because you can't wait after 3 rings. Saddly, a complete ring of red: You can't do anything about it, it can't be repaired, but check the power wire and reattach it, there's a little glitch where if you loosen the wire, it does that. Good luck!
tip
How to get rid of xbox 360 red rings of death
  1. turn on x box
  2. let it sit for a hour or two
  3. shut it down wait a few second
  4. turn on xbox
  5. fixed
  6. if this dosent work follow next set of tips
1. turn on xbox
2. let it set on for a day or two
3.turn off wait a few seconds
4.turn on
5. fixed
2answers
My xbox 360 freezes after being on for a couple of minutes. How do i stop this
If it freezes and then the next time you turn it on has red lights on the console display check out the corresponding Microsoft articles for the number of red rings on the display. They appear in quadrants on it.
1 red ring
2 red rings
3 red rings
4 red rings
If you do not have any rings, your console may just be overheating. Give it a while to cool down and if that doesn't work, give Microsoft a call: 1-800-4MYXBOX. Good Luck!
2answers
My xbox 360 keeps freezing when i put it on then when i turn it off it gets 3 red lights
You have the 3 rings of death. You need to send it to Microsoft. The machine can't be fixed with 3 rings. sorry.
2answers
System error flashing red lights
You need to have the motherboard fixed, do to this you need to take the xbox360 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually used the same method to fix over 450 Xbox360 units with no problems at all, barring a few (but i have done nearly 500 so you expect a few problems along the way), you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
1helpful
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Lcd
try rsetting the iPhone:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3answers
My xbox keeps on freezing
im not an expert or nothin but it mite b over heating this depends where the xbox is placed
My xbox 360 keeps freezing!!
wrap your 360 in a towel (Completely Covered), turn on the system for about 10 minutes, turn it off, then back on again and and it should work.Although this fix only works fr about three hours it works over and over but the problem you have can also be fixed by replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your 360. But my second solution should only be used if the warranty is void
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
