What are the wiring colours to the rear light cluster. i.e. what colour wire goes to the near side flash, the fog, offside flash, offside tail, brake, near side tail and reverse.
Many thanks
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Here is your solution » BMW »
Buick »
Chevrolet » Chrysler » Dodge » Ford » GMC » Honda » Hyundai » Jaguar » Lincoln » Mazda » Mercury » Mitsubishi » Nissan » Oldsmobile » Pontiac » Saturn » Subaru » Suzuki » Toyota » Volkswagen » Volvo a31
