Question about Panasonic VIERA TH-C50FD18 50 in. Plasma HDTV
How do i set up my blueray,hometheatre, andgame systems to my panasonic plasma
Posted by jacksonaudri on
electronic & computer repair& servicre
  • Panasonic Master
  • 12,061 Answers
  • nolly_98 Apr 28, 2011
    I've got the service manual already. Thanks anyways.
Panasonic TV codes
0318,0367,0333,0362. Try these codes. For more information http://electrohelponline.blogspot.com/
Nov 21, 2013 | Vizio 50" vp50hdtv10a 1080i widescreen...
Why do USB video's play through LG Plasma but not through Panasonic SC-BTT190 home theatre system?
Its really a software type problem i have a sony hometheatre that wont play certain videos. When tvs/home theatres are made they get whatever software that is put in witch most videos require the basic stuff sometimes its outdated or just not compatable.
Jan 02, 2013 | Panasonic Sc Btt190 3d Blu Ray Home...
I HAVE A 50" PANASONIC PLASMA TV THAT I WOULD LIKE TO HOOK TO DISHNETWORK AND A SONY SURROUND SYSTEM AND A BLUERAY PLAYER. dOES ANYONE HAVE A DIAGRAM OR CAN EXPLAIN HOW TO DO THIS?
The owner manual will have diagrams for this and images, also Dish may come out and set things up correctly and may or may not charge for that--get it done the first time right.
Dec 17, 2012 | Panasonic Televison & Video
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Hi ther i have a panasonic sa-nc9 hometheatre system and it is showing the f61 error message
THE F61 ERROR USUALLY MEANS A FAULTY FAN,BUT IT SOMETIMES CAN BE FIX JUST BY GIVING THE FANS A GOOD CLEANING.
Oct 05, 2010 | Panasonic Audio Players & Recorders
CONNECTING THE SET TO MY SURROUND SOUND SYSTEM.
What surround sound system can I buy to go with my panasonic viera th-50px80u plasma tv. One where I can here sound from cable and bluray
Jul 03, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Unable to get home theater sound on cable tv mode
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Aug 17, 2017 | Panasonic Home Theater System System
I bought a panasonic 50" viera plasma tv (50hd18) a panasonic suround sound sytem (scpt956) and a panasonic blueray player (pbd35ak) Im trying to hook this system up using the hdmi cables but my...
See if oyu can buy a HDMI selector box, does the sound system have a dvd player in it? IF so I would go with S-video instead of hdmi, save the HDMI for the blue ray player. What is the very first item you have listed up there? PAnasonic what? LEt me know, hope this helps.
Dec 11, 2008 | Panasonic Televison & Video
Panasonic VIERA TH-C50FD18 50 in. Plasma HDTV Logo
340 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
