Question about Samsung AS18A6RB Air Conditioner
Wiring standard for Split AC 1.5 Ton
In my house ...Iam using samsung split AC..1.5 Tons ..which normally takes ..6 to 7 amps of current...(1.6KW) If I see my house electrical system ..Iam having 16Amps Socket and wiring is 320 gauge ...
my ac mechanic was telling I need to replace with 720 gauge wiring ... my question is is it really required change to 720.
If I continue to use 320 gauge ..is there any risk ...involved.
Thanks
Ganesh
Posted by djganesh1980 on
  • zaheera9 Sep 09, 2013
    hi sir recently i installed a racold water heater 2000 watts for this 320 wire suffice or required 720 wire
D. Floyd Kolb
  • Samsung Master
  • 43,501 Answers
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
heatman101
Posted on Apr 16, 2010
abhi
    New Friend:
Same, problem to me.
yesterday i brought 1.5 ton ac, house having 320 wiring.
distance: in my apartment , all the meters are in ground floor, room is in first floor.
can i replace whole 320 wire or can i add extra 720 wire for only ac.
Posted on May 25, 2013
airport_pilo
    New Friend:
Nothing will happen when u run AC in 320wire, but u use another electronics things in same wire it get heat and burned, so use 720wire always
Posted on May 04, 2012
bijay kumar
    New Friend:
How much mm cable requireof use 1-ton(split)ac?
Posted on Mar 01, 2018
EDDY
    New Friend:
I have never heard in my life anyone running AC on 320 gauge wire. I think it's just not possible. U need atleast 722
Posted on Jan 21, 2013
  • EDDY Jan 21, 2013
Explain the difference between static electricity and current electricity
Static electricity...
Generally considered a nuisance... can cause serious damage to electronic equipment... (it is STORED power)
Thunder & lightening are STATIC electricity...
Wiki definition included (below)
For commercially available ELECTRICITY...
(usa) "currents" ... All electricity functions because of a DIFFERENCE in potential. When you start adding wires then you are harnessing that potential DIFFERENCE into usable energy.
Direct current & Alternating current... Generally referred to as "AC" & "DC"
Most all of the power grid you are looking at on power poles around your community... have "AC" flowing on the power wires
good for powering residential housing and commercial power applications
Immediately below those wires ... The phone wires
have to run about 10 feet below the "AC" wires...
Phone systems run on "DC" because it is quiet
(communications systems).
Alternating CURRENT can be rectified into Direct...
and Direct CURRENT can be inverted into Alternating.
Generators,
solar panels & BATTERIES output DC
Which can be accumulated and stored.
Alternators
output AC... and because AC is less susceptible to magnetic interference... it can travel great distances with very little loss.
Very interesting topic for further research ... and the principals of both... as argued by no less than Nicola Tesla & Thomas Edison.
Hope this helps
Static electricity
Carnac the Magnificent
Apr 10, 2017 | Televison & Video
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
We have an older model Lennox ac model #HS26-461-P and we are trying to find out what the tonnage is. Can you tell me where to look or if you know what it is will you please tell me?
The answer that (TheMobilian) left couldn't be further from the truth, of offense. So you're saying if you have a 1000 sq ft house with 4 bedrooms you'd have 4.5 tons of cooling? That's insane, the compressor in that system would be shot in about 6 months from short cycling. Their are many factors in sizing equipment, but none of them involve how many bedrooms you have. If you don't know how to calculate load from windows and insulation factor, then you can use the old (1 ton per 500-550 sq ft) that will get you close.
Jun 18, 2010 | Heating & Cooling
Wiring standard for AC
I see right now you are talking metric calculations so I am pointing you Click Here=> Wire Size Calculator I am not sure unless I did the conversion in metric. It is possible he is correct and trying to prevent harm or a fire. In the end of course the decision is yours. Here you can use you language and Math to come up with answers. With electricity always use the correct wire for amperage and distance. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Sea Breeze
Apr 19, 2010 | Samsung AS18A6RB Air Conditioner
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
6,450 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
