Question about Honda Maxus Pressure Washer MX5222
Hi I just bought a Honda pressure washer. The
Hi I just bought a Honda pressure washer. The instructions tell me to replace the travel pump plug with the supplied vent plug. I have done this but when i run the washer oil spits out of the vent plug. The washer now needs more oil. Should i put the travel plug back in? Please advise?
Posted by philiprutter on
NOT ME
  • 2,841 Answers
You just bought it which means it is under warranty. Take it back where you bought it or call Honda. You must have the vent plug installed to use the machine. If it is blowing oil out the vent plug then it is either overfull or it is building up pressure for some reason. Make sure it is not overfull and if not, then call Honda and avail yourself of the warranty. If it is overfull, remove enough oil to get it to the proper level.
Posted on Apr 16, 2010
How do you fix low pressure on windshield washer fluid sprayer.
Its just plugged up, probably right at the nozzle it's a pretty tiny hole. To clear it out you need to find a small diameter wire that will fit inside the hole to clear the blockage. Something like a small gauge sewing needle or a straight pin. It can also get plugged up in the rubber tubing. Usually you can just blow through it with lung power. Just pull the tube off at the nozzle and run the washer this will tell you if it's the nozzle or the tubing.
Jan 22, 2011 | 1994 Honda Accord
My Honda GCV160 Pressure washer runs great, but isn't creating any pressure out of the nozzle. Not even a drop out of the wand. Its been on hiatus while I've been recovering from an injury for 3mos. It...
Take hose and gun off pump.
Start engine.
See if pressure comes out of pump.
Next, remove water hose and look at filter washer.
Clean or replace filter washer.
Turn on water and it should come out of pump on other side.
These steps will tell you if problem is water supply or pump.
Sometimes the problems happen because the gun lever is bad.
Hook up hose but not the gun
See if pressure comes out hous.
These steps will tell you if problem is gun or hose.
Oct 25, 2010 | Honda Garden
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
I just bought a replacement pump today. Model
The oil will be in the stainless steel or silver colored part of the pump. If there is no access to this part then the oil is put in there by the manufacturer. I believe the small red plastic plug you speak of covers the overheat blow off valve. Just leave it. When you run the washer for a long time you may see some water spill out of there. The only way to change the oil is to separate the two pump sections. Not advisable without some knowledge and the correct tools
Aug 11, 2009 | Annovi Reverberi RMV2.5G27D Pressure...
Pump with upgraded pump only getting half power
if you bought a new pump make sure its the correct type
then check for a unloader the adjustment part like a handle or an Allen screw on the head of the pump
dismantle grease up and replace
Aug 02, 2009 | Honda Pressure Washer PSI 3000
Where do I look and what am I looking for when checking pump oil level . Honda / Husky 3200psi bought reconditioned from home store with out papers .
The pump oil reservoir and pump pistons are between the Honda engine and the business end of the pump. It rarely brass, like the pump. It may be square or tubular. Some of these units have a site tube on the side, some don't. Some have an oil drain plug (bottom) and a plug to put oil in (top). If not, you have to take the pump off. Either way, be sure to use NON-detergent oil and only fill it about 1/3 to 1/2 full.
Jun 10, 2009 | Honda Pressure Washer PSI 3000
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Honda Maxus Pressure Washer MX5222 Logo
343 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
