I have a Pioneer AVH-P6600 and I've tried to use a 3 prong switch in order to "turn on" and "turn off" the parking brake check wire. There is a positive prong, a negative prong, and a positive out prong. I connected the negative to the ground wire on the radio and then connected the postive to the power wire on the radio and then i connected the parking brake wire to the postive out prong. I have tried toggling it on and off 3 or 4 times and I still can't view video. Can anyone please clarify how I need to do this using the switch? Preferably using the switch I have now because I have already installed it (cut a hole in my dash to make it fit).
The parking brake wire has to connect to ground when the switch is in one position and connect to nothing when the switch is in the other position. I think if you disconnect the positive wire from your switch that might do it. If not, leave the positive wire off and try the remaining two wires, ground wire and parking brake wire, on different prongs of the switch.
You have to connect the ground wire and the parking brake to get pictures
