Question about HP LaserJet 3330 All-In-One Printer
Scanner bulb warnning - HP LaserJet 3330 All-In-One Printer
Posted by orionbaja on
Buddy Mcsparrin
  • HP Master
  • 1,684 Answers
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 26, 2010
John Street
    Guru:
  • 513 Answers
Warning or warming?
A scanner lamp warning means no scanner lamp. Unit needs service. No user safely serviceable parts
Posted on Apr 16, 2010
"position bulb failure" warning is on and we have
Some models just have this as warning light, check back-up or reverse bulbs.
May 30, 2011 | 2006 Volvo S60
Will not print. Message says
Your scanner bulb is not warming up. It would cost more to repair it than buying a new printer.
Nov 29, 2009 | HP LaserJet 3030 All-In-One Printer
Won't print; making a funny crunching noise; dialog screen says "scanner bulb warming up"
This is a problem in scanner section on your printer.You need to disassembly the printer and pull out the scanner section.Open the cover of scanner section and you'll see the mirrors inside.You need to clean the ash from these mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Oct 28, 2009 | HP LaserJet 3330 All-In-One Printer
My hp 3030 printers shows bulb warning up and make noise how can i solve it ?
Oct 13, 2009 | HP LaserJet 3330 All-In-One Printer
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
Scanner error message hp laserjet 3030
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Jul 14, 2008 | HP LaserJet 3330 All-In-One Printer
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Scanner not working - get error message
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Nov 02, 2007 | Epson Perfection 1240U Flatbed Scanner
HP LaserJet 3330 All-In-One Printer Logo
739 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
