Question about RCA D52W19 52" Rear Projection Television
RCA Rear projector screen will not come on from
RCA projector screen will not turn on from power button,why?
Posted by smp78660 on
Jason Johnson
    President:
  • 1,619 Answers
Bulb lamp may have failed.
Posted on Apr 16, 2010
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
1helpful
3answers
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
I have a 52 in rca projection screen tv that looks like its stuck in 3d mode, how do I fix it?? Its got red and green lines everywhere. It was in storage outside for 6 months as well
It has dust on the lenses. My RCA rear projection uses a 7/64" allen key. take the speakers' cover off and then remove (I think) the three screws below the button pannel, and 2 on each side on the back on button pannel. the projectors should be easy to see. I turned mine on when I cleaned the lenses so i could tell if there was any streaks.
Once the lenses are cleaned go to auto convergence in the setup menu and your problems should be fixed. Good Luck.
1helpful
2answers
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
RCA HDTV HAS COLOR SPLIT ON SCREEN GREEN & RED
I HAD THE SAME ISSUE. I WAS LUCKY, MY TV WAS UNDER WARRANTY. THEY SENT IT TO BE FIXED. THEY REPLACED 2 CONNECTORS FROM THE PROJECTOR AND THE ON/OFF BUTTON. THE WIRES WERE NOT TRANSMITTING THE SIGNAL/ OR A SHORT IN IT. THEY REPLACE THEM ALSO. IT WOULD TAKE MY TV ABOUT 2 MINUTES TO TURN ON. THE COLORS WERE OFF. AND I HAD DOUBLE OR TRIPLE VISION. THEY ALSO REPLACE A FUSE IN THE PROJECTOR PART OF THE TV. THE FUSE ITS SELF COST ABOUT 275.00 WITH OUT LABOR. I DIDN'T PAY A THING I WAS ONE WEEK SHY OF MY WARRANTY TO BE OVER. EMAIL ME IF U THINK THIS HELPED. THANKS [email protected]
6helpful
52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
