Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
I have a Coleman Powermate Powerbase 4000 Extended Run Plus Generator.
Model - PM54a4302
Motor runs fine, not AC output. Brushes are fine. Does anyone have a test procedure for testing Field excitation. Also would like to find a manaul for it
Fred Yearian
  • 5,603 Answers
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Posted on Apr 16, 2010
Testimonial: "Thanks for info. I had it solved. I found the 130uf 200V rated cap was bad. 12 volts to the brushed did re-energize the field, power is operating. TY"
Anonymous
    New Friend:
Can I get information on disconnecting the generator from Coleman PM54A4302 motor?
Posted on Oct 05, 2010
1 Related Answer
Sheldon Dedek
  • 912 Answers
SOURCE: I have a Coleman Powermate Powerbase 4000 Extended
Well, its not exactly a published procedure, but this is what I would do.
Check field for continuity between leads, as well as continuity from each lead to the core. Between leads, you should have continuity, but you shouldn't be able to measure anything (perhaps in megohm range) between leads and core.
Once you have continuity, check your diode. You should have continuity in one direction only. If not, replace diode. Don't worry about capacitor / regulator at this moment.
Check stator winding for continuity between leads, (don't forget the 12 volt winding too), as well as between each lead and the core. You should not have continuity to the core from any lead.
Make sure breakers are reset, then check continuity through them. Should have it, replace if not. Same goes for the outlet itself.
Reassemble the engine, and start it. Check for a DC voltage at the 12volt battery charger port. If you have it, then your capacitor / regulator is shot. If you don't have it, replace the diode (even if checked good) and the capacitor / regulator. If still don't have 120vac, you can try to flash the field by momentarily touching a small lamp battery (6 volt lantern) to the core, and to one of the brushes. Just for a moment. Then restart. Exact flashing instructions are usually in the user manual.
Have fun!
Posted on Jun 12, 2010
No power output at all
If your field winding is good, try to recharge it with a 12 V battery, connected for a few seconds to the field "+" and "-".
Jun 30, 2010 | Coleman Powermate Premium Plus 6250W...
I have a old Coleman powermate Model PC 54 5000 I have no AC Power. I have checked the rotor and stator for continuity in the windings, no problem. I have tried exciting the brushes, got a spark, but...
How did you put exciting voltage to brushes? Plus to plus, minus to minus or no mater?
The condenser can be checked by a capacitance meter or an Ohm meter.
Diodes also by a diode test with a multimeter. Reverse should be infinity, forward 0.5 - 0.7 V.
May 11, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate Powerbase 4000 Extended Run Plus Generator. Model - PM54a4302 Motor runs fine, not AC output. Brushes are fine. Does anyone have a test procedure for testing Field excitation. ...
Have fun!
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Powermate PM0496500.02 No voltage output
Here is a simple test to check field and other wiring. With engine off apply 12v ac 1 amp to 110v outlet plug on generator. This will energize the field windings and should cause the armature to produce dc voltage at the brushes and produce a nice magnet. If there is a short in the field or broken wire or shorted capacitor there will be no dc reading at the brushes. . This test is the opposite of what actually occurs when the engine is running. That is the armature produces a magnet fed thru the windings, regulator and brushes. If dc voltage is present at the burshes, remove 12v ac and start engine to check for output. enjoy
Oct 23, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Generator powerbase 4000 model #PM0543800
I have to leave a comment for cfa6094. Your pretty good at flexing your cyber muscles. I am a service tech in the repair field and deal with people like you all the time. If you are the owner of the equipment you should properly maintain your equipment. Sounds like you are not very organized. Sound more like crises management to me. Is mrfixit the only person you asked about this problem? One more thing, sound like you are a bit of a procrastinator to me. LOOK AT ME NO SPELL CHECK!
Oct 11, 2008 | Coleman Powermate Powermate 5000W...
Coleman generator 4000
powermate went out of business , but here is a website http://www.powermate.com/contact.php
you can probably get a off/ on switch at your local small engine repair shop. it probably can be any switch for a gen.
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,767 people viewed this question
Top Coleman Electrical Supplies Experts
Sheldon Dedek
MrJunk
Level 1 Expert
Tim Venetis
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
