Question about Maytag Neptune FAV6800AW Top Load Washer
Water keeps getting into my bearing.
I have a Neptune FAV6800AWW. Water keeps getting into my bearing. I have the washer that does not have the upper bearing. This bearing is only 4 months old and there was a considerable amount of water in the bearing. What could be my problem?
  • 526 Answers
I feel you have a Tub Seal leak.
Did you replace the Clutch Pulley or a repair service?
You are talking about the Clutch Pulley One-Way Roller Clutch bearing in the white bearring plate correct? The First two digits of your serial number are 12 thru 17. What are the first two digits of your serial number?
To replace the Tub Seal you need to remove the spinner assembly. That means you have to remove the outer tub. A bigger job but several on this forum have completed it including myself two weeks ago on a Series 10 FAV6800A.
I will point you to a link most recently where a form member replaced Outer tub bearings on his Series 15. If your wash basket spins up to 850 rpm with no Outer Tub bearing noise I would just do a tub seal replacement this round.
You would need the Tub seal see Sears Parts Direct. I would also pick up the Tranny O-ring seal (series 10) .
Some links on Outer Tub Bearing replacement.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
If you replace the tub seal make sure you remove this sleeve that will more than likely stay on the Spinner Support when you remove. See Page 49 of the Service Manual. Here is a real world pic of the sleeve on the Spinner Assembly.
I did break off a Spinner Bolt even after heavy soaking in Liquid Wrench be careful;
There should Water keeps getting into my bearing. - 76bd389.jpge oops!
Good luck and post back if I can help.....Rich
Posted on Apr 16, 2010
6ya staff
SOURCE:
Leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you get in to the back of the washer?
The FAV6800A and FAV9800A only have access thru the front panel and washer top once released fromt the base......no rear or side access. See Pick of Outer Tub removed for Tub Seal and bearing replacement.
Google ""16022808.pdf"" to find the Service Manual.
Page 33 will show ou how to release the top cover and page 41 for front cover removal.
If you have wash water leaking down on the Clutch Pulley I feel you have a Tub Seal leak. The issues could be related to the drain hose/drain pump or cracked outer tub.
I don't troubleshoot on this forum to difficult to carry on thread. Google ""Neptune TL Washer FAV6800AWW"" or ""FAV6800A/FAV9800A Outer Tub bearing replacement"". Two DIY forums I frequent that I feel are true DIY forums.
Sep 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Have Neptune FAV6800AWW top load, washes when it gets to the rinse cycle it stops with water in. If we remove the clothes and wait a while we can get it to complete. The code we are getting is DR which...
Are you sure the error code is DR? Could it be DC an unbalance error code. Google ""16022808.pdf"" to find. Is the washer banging around in Spin Cycle? If so this is a Clutch Pulley issue.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
DR is not a listed error code in the FAV6800A/FAV9800A Service Manual.
Aug 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl top loader is stuck on 23 minutes and just keeps going back and forth. There are no error messages. and water is sitting in it. Any ideas?
don't visit this site very often and I don't want to troubleshoot FAV6800A or FAV9800A issues here.
I have two DIY sites that I try to provide owners support as a knowledgeable owner.
You problem is related to a Clutch Issue. Google these keywords ""[FIXED] Maytag neptune FAV6800aww wont spin""
It's a long post it was difficult for me to pull accurate info from the owner for the issue. Fo him the Upper One-Way bearing on his machine was seized. All of these machines are ready after 6 years + of operation are ready for a Outer Tub rebuild. It's a few hundred dollars to do if you have to replace the Clutch Pulley as part of the process.
But one step at a time read the thread [FIXED] Maytag neptune FAV6800aww wont spin and see if this is a DIY project for you. It
Jul 02, 2011 | Maytag Neptune FAV6800AW Top Load Washer
During a cross-country move, several heavy items were loaded on top of the door of my Neptune top-load washer; now the water jets at the back of the machine are misaligned with the door and water sprays...
Give it a try you might beable to bend it back. See the pic below. Grab the Service Manual it with help you with
disassembly.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Good luck.
Apr 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
Good luck.
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer starts and after about 5 minutes gives out... i get an nf code... anyone dealt with this
That's a No Fill error code. Is there any water flowing into your machine?
May be a block in the in the Water Inlet Valve. If it was false I feel you would have to break out the mop for flood/over fill condition. Did you try to fill with a mix like Warm/Warm selction?
If you want to troubleshoot further go to a real DIY forum.
Google this Neptune TL Washer FAV6800AWW
Feb 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
444 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
