Question about Mitsubishi WS-55311 55" Rear Projection Television
Ws 55311 turns on and then off after 2 seconds is there a a simple fix or do i need a repair man. if its a part i could replace i can do that. If its a on board soder i can not any advice would help
Posted by jpdsec on
  • Robert Hinson Feb 18, 2012
    If you haven't thrown it away, press and hold the menu and input button for 5 seconds. It should start blinking. Count the number of blinks. There should be two sets of blinks. Which will repeat 5 times. A code 2-1 is x-ray protection circuit. 2-2 is short protect circuit. 2-3 is Horizontal Deflection Failure. And 2-4 is Vertical Defection failure.
Anonymous
    New Friend:
  • 8 Answers
Throw it in the trash
Posted on Apr 16, 2010
Mitsubishi WS-55311 55 In. Rear Projection Television will power on but won't stay on
When it shuts down have you tried accessing the self diagnosis feature to retreve the error code?If so whats the blink code your getting?
Feb 10, 2013 | Mitsubishi WS-55311 55" Rear Projection...
How do I replace convergence chips in a Mitsubishi ws-55311?
Tools and skills must have.Tools,a soldering iron,desoldering pump or desoldering braids,solders?Skills,must know how to do the basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy the convergence kit to repair it ur self.A kit also came with a instructional DVD disc.The shop,will cost u $300-350 for parts and labors.
Oct 15, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi ws 55311 power not working
Try website like Tvrepairworld.com to buy a refurbish DM power board for the replacement or parts.U know soldering?Buy capacitors for repalcement.
May 14, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Green lite turns on for 2 second and then turns
Please listen and try this:
When the power light comes on and goes off, on the front of the set press BOTH the Menu and Input (Device) buttons at the SAME time and HOLD them both for at least five seconds and then release both.
The power light will blink a two digit error code and will repeat it about 5 times. To get it to repeat you would have to unplug the set and turn it on again etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
SD TECH
May 13, 2010 | Mitsubishi WS-55311 55" Rear Projection...
2-2 with blink code
You need a convergence repair kit. You can get one at www.tvrepairworld.com
Sep 22, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Blue color out of focuse
Replace both of the STK392-110 Convergence ICs. You can get them at the following link with free instructions on how to replace them.
http://servicemanuals.vstore.ca/
May 22, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi tv ws-55311
Mine did the same thing. It was too much money to invest in old technology. I chucked that baby to the curb and got a 42" LCD. LOVE IT!!
Apr 25, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Bad convergence, now wont turn on at all.
The convergence ICs have failed and thats what is shutting the set down. You will need to replace both convergence ICs they are STK394-250 you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures s you can do the repair yourself. Here is the link.
Jun 30, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
179 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
