I have removed the cartridge, the small innerI have removed the cartridge, the small inner brass piece and can't remove the larger inner piece any suggestions. I have tried to soak a sponge with white vineger no luck
There is a small "U" type clip that comes down in front area to hold it in, I assume that has been removed. The new cartridge should have come with a small tool (usually plastic) that you put over the cartridge, push it in, and turn the body of the cartridge, and it should start to ride up on higher brass sleeve and start to pull itself out. If you look at vertical part of cartridge, it is sitting back in on low spot of the sleeve. That tool, or a pair of strong needle nose pliers,needs to be against the sides of the vertical part of the cartridge, in such a way that when you rotate the cartridge, it rides up on higher part of sleeve, and pulls itself outward.
