Question about Frigidaire FEF336BC Electric Kitchen Range
How to fix the F13 error in this stove
Whenever i touch any of the bottoms for oven it saying F13 error and it does not work.how to fix the F13 error in this stove
Posted by pomohammadia on
  • Anonymous Mar 18, 2014
    F13 ON STOVE TOP UNPLUG IT F13 STILL FLASHING SO WHATS A EOC?
Dan Webster
  • Frigidaire Master
  • 8,220 Answers
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 16, 2010
  • Dan Webster
    Dan Webster Apr 16, 2010
    EOC= oven control
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
Oven does not work
What is the model number listed inside the oven door area or the storage drawer on the bottom (if it has one).
Jun 05, 2013 | Kitchen Ranges
I have a Frigidaire Elements stove. When I went to preheat the oven I got a constant 'beep' and a code, F13 ERR. Please help Thank-you Anxious in Indy
Hi akadiki,
This error code F13 description is a bad Clock ERC. The steps below will help you determine whether the ERC or touchpad is defective.
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F13 code comes back (usually accompanied by a beeping sound).
7. If F13 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 15, 2011 | Kitchen Ranges
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
What is a f13 error code on a Frigidaire Gallery smooth top stove
Hi danair2,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Aug 14, 2009 | Kitchen Ranges
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Model FGFL87DSG error code F13
hi there,
here is what you can do:
disconnect power to the stove completely and flip the corresponding breaker on and off on the breaker box.
let me know if this helps.
Oct 12, 2008 | Frigidaire Kitchen Ranges
Frigidaire CPL-EF398DCK
If unplugging doesn't reset it, then EOC electronic oven control is most likely defective
Nov 15, 2017 | Frigidaire fes365e Electric Kitchen Range
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
1,387 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
