Question about SanDisk Sansa m240 MP3 Player
I got a problem with my mp3
I have a sandisk sansa m240 and i have 87 some odd sonds on it and i cant delete any of them i can add and delete other songs but it seems that the same 87 songs wont delete they dont show on my computer at all in order for me to any body help??
  • 820 Answers
Transfers onto the m240 can be done in 2 USB connection modes:
MTP mode: Media Transfer Protocol using software, e.g. Windows Media Player 10 or higher.
MSC mode: Mass Storage Class using Windows Explorer, looking in "My Computer" viewing the player as a removable disk.
Typically, songs put onto the player in MSC mode can not be viewed in MTP mode and the other way around.
Switching to MSC mode in the player's menu:
Look in the player under Settings Menus > USB > select MSC for using the "copy and paste" or "drag and drop" method for transfers in "My Computer".
When Auto Detect is selected, it depends on the configuration of the computer, what setup for priority has been installed.
Forcing the player into MSC mode:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Information for the USB connection mode and how to make hidden files in XP and Vista visible, on the support site:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for the m200 series players (readable with Adobe Reader):
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Don't hesitate to add a comment.
Posted on Apr 15, 2010
Hello, Am using Sansa c200 . am unable to delete songs which i hav copied into player. and even i cant see any songs on computer(my music folder was showing empty) .i even tried to format the disk ..but...
See this tip posted here on this site. It may explain what is going on. copy this address into a new window -- http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If that does not work go here and download the Sandisk utility. http://kb.sandisk.com/app/answers/detail/a_id/156
Jan 16, 2010 | SanDisk Sansa c200 MP3 Player
I cant empty out the sansa so that i can add more music
format it and see if that works.this will delete all of your songs so back them up first.if you want instructions on how to format email me at [email protected]
Jun 29, 2009 | SanDisk Sansa m230 MP3 Player
Cant delete music from sansa mp3 player
sir, as there will be a usb cable given along with the device, you should just connect that tothe computer. a window will open showing the already containing songs.you can just right click on the selected songs in that window and select the delete option.the songs will be deleted.
May 28, 2009 | SanDisk Sansa m240 MP3 Player
Cant delete songs from player
Paul,
You can't delete songs from the player itself. You have to plug the player into a computer. Then go to the player, find the songs you don't want, and delete them.
Yeah, seems odd to me too. But Sansa have confirmed that there isn't any way to do this from the player. Cheers!
Jan 23, 2009 | SanDisk Sansa e140 MP3 Player
Cant add songs after i made space
Have u checked if the songs u put in have extensions that are supported by the player............in ur case check if some of the songs are .rm or something and not .mp3...........only files with .mp3 extensions will be supported
Aug 28, 2008 | SanDisk Sansa e250 MP3 Player
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
i don't no how to delete music off my sansa mp3 player with windows media player
Feb 13, 2008 | SanDisk Sansa e250 MP3 Player
Songs
to add or delete songs you simply view it as a hard drive then drag and drop the sings you want on the folder marked sansa.  to delete do the same thing in reverse.
Feb 12, 2008 | SanDisk Sansa m240 MP3 Player
Deleteing songs
You can delete them thru My Computer. Double click on the Sansa (m200), inside you will see a Music Folder. Inside is your individual tracks, separated by album names. You can add or delete all music from here. Best of Luck.
Oct 09, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Deleting
You can manually delete the music thru My Computer. My Computer>Device Name (c250)>Media>Music You can see all of the music by albums and delete what you want. Please add to this question if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa m240 MP3 Player Logo
171 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
