SOURCE: How to change and upgrade the memory
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
SOURCE: i cant find my wireless switch on my fujitsu
Try hitting fn+f1 at the same fn= function key hope this helps you
