HP Pavilion m7680n  PC Desktop Logo
Question about HP Pavilion m7680n PC Desktop
Troubleshooting wireless home network using windows xp
Posted by mrasalazar on
Anonymous
    Guru:
  • 135 Answers
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
  1. Click the Start button, click Network Connections, and choose Show all Connctions.
  2. Click the Wireless Network Connection icon with your right mouse button, then choose View Available Wireless Networks.
  3. Choose the name of the 2Wire access point from the Available networks list.
  4. In the Network key field, type the hexadecimal key to access the wireless network.
    Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
  5. In the Confirm network key field, type the hexadecimal key to access the wireless network again for confirmation.
  6. troubleshooting wireless home network using - wnc_xp_3.jpgonnect button.
Posted on Apr 16, 2010
Cannot connect to wifi
The following can be applied to any routers. These are the general troubleshooting steps.
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
If problem persists, contact your router's manufacturer.
I hope this works for you. Good Luck!
Thanks.
Mongkey
tip
Network Troubleshooting in windows
<p>Some Time Network trouble shooter faced some problem in but they can't solve out where is the exact problem. Yes it create critical situation some time to find out where the problem is. In windows based OS have a feature to take out problem. Network trouble shooter is the feature where we can recognise the trouble of hardware, software or network. Here I will describe about <span>how to troubleshoot a Windows XP-based home network. Usually it will describe also about a network structure, how to use the Home and Small Office Networking Troubleshooter, and how to troubleshoot basic connectivity, and how to resolve file and printer sharing issues. If you have problems with your home network, follow the steps in this article to help isolate and troubleshoot the configuration of your home network's basic connectivity, and file and printer sharing. First, try to identify and resolve the issue by using the following steps. </SPAN><br> <p><span><span> </SPAN></SPAN>At <span>first you have to know the kind of network structure that using there. If you are not sure, go to the "Home-network structures and their configurations" section. To identify the problem first </SPAN><span>Click starts and then click </SPAN>Help and Support<span>. </SPAN><span><span> </SPAN>After that </SPAN><span>Pick a Help Topic, click Networking and the Web. </SPAN><span><span> </SPAN></SPAN><span>Under Networking and the Web, click Fixing networking or Web problems, and then click Home and Small Office Networking Troubleshooter. </SPAN><span>Answer the questions in the troubleshooter to try to find a solution. </SPAN><span>Before you troubleshoot home networking issues, first determine the network structure you are using. The network structure is the arrangement or mapping of network elements such as links and nodes, and the physical connections between them. There are several common home-network structures.</SPAN><br> <p>If in that Lab the computers are connected to a hub, where only one computer has Internet connection shared by using Internet Connection Sharing<b><span>.</SPAN></B><span> </SPAN><span>In this configuration, the computer that shares the connection generally assigns IP addresses to other computers on the home network. The computer that is sharing the connection will have IP address 192.168.0.1 configured for the adapter that is connected to the home network. Other computers on the network will have addresses in the range 192.168.0.<span>x</SPAN>, where <span>x</SPAN> is a number between 2 and 254.</SPAN><br> <p><span> </SPAN>If t<span>he computers are connected to the Internet</SPAN> through a broadband connection, then<b><span> </SPAN></B><span>this configuration is also known as an edgeless network. In this configuration, the computers on the home network each have an IP address that is provided by the Internet service provider (ISP). The addresses that are used vary, depending on the ISP. </SPAN><span></SPAN><br> <p><span>So Network trouble shooter is very useful and easiest process to identify or troubleshooting a network problem.</SPAN>
1helpful
2answers
My computer died we redid widows xp disk and it came back now i dont have wireless how do i get it back
Hi, you will need to reinstall the wireless card drivers, if this came with wireless as standard you should be able to download the drivers from the manufacturers support website, if it was added later on then it should have came with an install disc with the drivers on it.
Hope this helps
John
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
My computer sees the home net work but cannot connect to the internet. Internet works fine when I plug cable directly to computer
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
1helpful
How to connect to a wireless point outside the home.
Click Here for sttep by step instructions on how to connect to the wireless network and troubleshooting steps
9helpful
3answers
Running to slow and wireless not responding
Is the Wireless Zero Configuration service running? To determine if the Wireless Zero Configuration service is running, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type cmd, and then click OK.
  3. Type sc query wzcsvc, and then press ENTER.
  4. If the Windows Zero Configuration service is running, the words "STATE : #RUNNING" will appear.
  5. If the problem is in the user interface, collect a screen shot of the issue, if you can. To collect a screen shot, press ALT+PRINT SCRN.
Basic troubleshootingTo troubleshoot wireless network connections in Windows XP, follow these steps:
  1. Check the Windows Catalog at http://www.windowsmarketplace.com to determine if there is a Windows XP-compatible driver that is available for your wireless adapter.
    • If there is a compatible driver, install the updated driver before you perform any additional troubleshooting procedures.
    • If there is not a compatible driver, you may be able to use the network adapter, but its configuration and functionality may be very limited.
  2. Determine if the driver that you are using recognizes the Windows XP Wireless Zero Configuration service. To do this, follow these steps:
    1. Click Start, and then click Control Panel.
    2. in the right pane,click Network and Internet Connections.
    3. In the right pane, click Network Connections.
    4. Right-click Wireless Network Connection, and then click Properties.
    5. View the available options:
      • If you do not see the Wireless Network Connection icon in the Network Connections folder, or if you cannot view the properties, there is a problem with the driver for the wireless network adapter. To troubleshoot this problem, see the Driver installation issuessection.
      • If you can view the properties for the Wireless Network Connection icon, but you do not see a Wireless Networks tab, see the Drivers that do not support the Wireless Zero Configuration service section to continue troubleshooting.
      • If you can view the properties, and you can see and use the Wireless Networks tab, see the Drivers that support the Wireless Zero Configuration service section to continue troubleshooting.
      • If the Authentication tab is missing in the Wireless Network Connection properties, make sure that the Wireless Zero Configuration service is running.
2answers
Windows XP HOME NETWORKING ISSUES
If don't have the windows instalation disk then don't use windows use Puppy linux free live cd
with this os you can network, go on the internet an alot more
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
