Sd: Suds lock. Detergent overdose. Clean out the soap dispenser. Remove the bottom panel and open the pump drain. F21: Long drain. Possible cause: Clogged filter, clogged/failed pump. Run some loads without detergent then use these amounts:
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
F21 Fault Code Repair LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
thank you for your tips i cleand out my pump filter and it was as easey as 123 my filter was full of chang and lint now it works great and your tips saved me 200 bucks ore better thank you all
