Hitachi 50GX30B 50". Rear Projection Television Logo
Question about Hitachi 50GX30B 50". Rear Projection Television
It went pop screen went black no power serge
Took back off red diode lights up inside
Posted by a_randy on
Anonymous
    New Friend:
  • 46 Answers
If you heard a popping sound chances are your lamp went out on you.You can purchase a quality replacement lamp at discount-merchant.com
Posted on Apr 15, 2010
Samsung PN43F500AFXZA plasma TV wont turn and no sound
Any ooze coming from under a cap? The simple fix is to get another mainboard for around $45-65 bucks online from lots of sources.
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
TheTV made a loud pop and the screen went black. Now I have blinking red lights.
You probably blew up a capacitor. Unplug the television and open up the back. Check for bad caps. You'll probably find a puffy one. Check the fuses to see if they're blown. If you find a blown fuse, start looking for bad diodes or a bad transistor. If you don't know what I'm talking about then don't ruin a good television set by poking your nose inside and blowing something else up or end up zapping yourself when you touch the wrong thing. Take it to a professional and get it fixed. Good luck.
2answers
My Drink-O-Matic DR-3 power supply HYS68-12-50 crackles and led light flickers. The machine does not cool. It was a gift and worked about 6 to 9 months.
I have the same machine, my power supply was humming and the light completely went out. I took it apart and tested the dual package diode and found one the of the diodes went bad. I un soldered it and cross referenced it with a different part replaced it and now it works
2answers
Turns on but will not display anything on tv no background or anything power went off yesterday but is on serge protector same as tv
Try a video reset:
While the PS3 is off (solid red led) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if that solved your problem.
2answers
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
