Xerox Phaser  8550/DT Thermal Printer Logo
Anonymous Posted on Apr 15, 2010
I have a Phaser 8550. That will not print any magenta/ pink. The test prints for that color come out purple. I check the ink resevoir on the print head, I didn't see any blue in the well. Any ideas
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 32 Answers
  • Posted on Jul 22, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
32
Questions
Helped
24494
Points
67
On the control panel go to trouble shooting > printing problems > advanced
If this doesn't get the ink flowing make sure you are not low on ink by checking the loader and if that is not it check the loader for cracked ink chips in the loader which may be preventing the ink from getting pushed down onto the melting mechanism. I had that problem once and fixed it by shutting the printer off, letting it cool and then laying it on its back side with front up in the air with ink loader open fish out the ink sticks and visually check for broken off ink chips and if none are seen. Do what I did out of frustration, unplug the unit and thru the holes in the ink loader stick a screwdriver in there and try to "lightly" scrape any petrified ink that may be stuck and not clearing out. I did this, felt a little resistance but no chunks or anything broke loose however the problem seemed to have been cured. I suppose I broke some ink loose after all. Good Luck.
Xerox Phaser 6125 prints pink
you cal also try to clean the laserwindow of the Magenta imaging unit
1helpful
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Xerox Phaser 8550 having color quality issue
If you are using third party ink sticks contact the manufacture and they will, if you use enough of thier product, send you a new print head and send out a tech to change it. Media Science is the most likely source of third party ink.
You can also switch to Xerox ink sticks and the colors will be correct after several purges to get rid of the old ink.
Harry
1helpful
Xerox 8550 Printer Magenta ink not working.
You need to run the eliminate light stripes. it should be in the menu, under troubleshooting, print quality issues. you can run this up to 3 times. you want the run the basic light stripes, not the advanced. If after 3 times running this, you are still missing jets, your printhead is bad. If you are using aftermarket ink, media sciences might cover the repair, if not, the printhead costs as much as a new machine. about $650+labor.
1helpful
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Printing pink
Change the magenta developer, maybe some ink was not original
Color printing problem
Most likely the print head has failed.
1helpful
3answers
Xerox Phaser 8500 color issue
In all honesty, I suspect the print head has some bad jets on it.
Xerox will not warrany it since there is the presence of non xerox ink in the print head.
When you have tried as much as you have with the maintenance cycles. I would suspect a bad printhead.
When the jets become blocked to the point where you cant get all the colors sprayed onto the drum, you get mismatched colors.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
