Samsung S1070 Digital Camera Logo
Question about Samsung S1070 Digital Camera
How do i change the shutter speed on a Samsung S1070?
Posted by alex_surf_ki on
  • FIKRET UNALIR
    FIKRET UNALIR May 11, 2010
    I think you want to use your camera manully. If you think so then I will give you some information. Please wait a few minutes and check my Solution.
FIKRET UNALIR
  • 239 Answers
If you want to use your camera manually. Then you should switch the MODE DIAL button(The top cylinderic button) to M position.
Then, by using the other buttons (firstly use arrow buttons) you may change the shutter speed.
Regards.
Posted on Apr 15, 2010
Software for s1070 samsung
You may need to install the software first
4helpful
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
Changing shutter speed on ST500
It's done in the "program" mode. Get your owner's manual.
When turned on, my VPC S1070 shows
This blog explains the problem you're having, and things you can try to fix it.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
They say about half the cameras can be fixed, trying their suggestions. Good luck, hope you're in the "fixed" half!
Problem samsung s1070, lens refuse to zoom out
does the samsung s1070 have action shout mode ?
Jan 12, 2010 • Cameras
4helpful
3answers
2helpful
How do you change shutter speeds on the Samsung digimax S500? I need to know how to change the shutter speeds and how to use the manual option on the camera in order to perform motion blurs and such.
Select Manual mode by turning the mode dial to M. Press the +/- button, then up/down to change the aperture or right/left to change the shutter speed.
This is on page 14 of my copy of the manual.
How to play back movie clips
i having a problem with D: 5f08 5e02
Top Samsung Cameras Experts
David Shaub
Paul Bade
Are you a Samsung Camera Expert? Answer questions, earn points and help others
