Question about Sharp MX-2700N Color Copier
Sharp MX-2700N how can I clear maintenace code CA?
Posted by jbarry776 on
abbas rezazadeh
  • 328 Answers
Enter code 20-1 start
Posted on May 27, 2010
Erro na sharp mx 3100n U2-80
On the control Panel, press the keys #*C* (pound, star,clear,star)to enter test mode. Enter number 16 and press the copy button. On the touch screen press "execute" and "yes". Press CA to reboot. The error code should clear.
Aug 03, 2012 | Sharp MX-2700N Color Copier
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
Reset code for h5-01
To reset an H5-01 code, enter simulation mode. To do this on the operation panel of the mfp hit
#, *, C, *. Then type in 14, execute. Then press Clear All, CA, to reboot the machine.
Oct 07, 2010 | Sharp MX-2700N Color Copier
Hello, We have a sharp mx2700n and it says: maintenace code TA is there any code wich makes this undone? thx in advance
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you
Mar 01, 2010 | Sharp MX-2700N Color Copier
What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Aug 01, 2009 | Sharp Office Equipment & Supplies
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
Call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Jan 16, 2009 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Dec 01, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
1,016 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
