Tv picture is pink with vertical lines sony bravia 32 inch XBR
My audio works fine and the remote is ok but my picture is distored and pinkish with many vertical lines. can it be fixed by myself and if i open the back up where do i look for the problem. can you help me
Re: tv picture is pink with vertical lines sony bravia 32...
It sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Unplug,replug the tv about an hour later.Let the tv reset it self.Go to the menu,go to Audio setting,go down reset.The tv audio will work again.Not,than ur Tuner board is dead.Must be repalced.
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options. If this is not the case then T-Con board sounds bad and needs to be tested/ replaced. Qualified tv tech will test and replace it. Thanks.
