It is not a common problem with this kind of phone, maybe the phone drop from you or you sat on the phone, anyway, the
problem is that the mouth piece on your phone is
malfunctioning that is why people call or people that calls you barely
hear you. All you need to do is to replace the mouth piece of your
phone and you will see that after the replacement of the mouth piece,
anybody that call you or people you call will hear you clearly.
Just
change the mouth piece as advice and you will see that the problem is
solve. meanwhile, you can be using hands free pending the time you will
replace the mouth piece.
The problem is that the mouth piece of your phone is bad
that is why the cannot hear your voice. I advice you get the mouth
piece of your phone replace because it is bad and that is why your
callers cannot hear you.
All you need to do is to change the
mouth piece of your phone and you will see that your callers will hear
after you have replace the mouth piece of your phone.
Meanwhile,
you can get hands free pending the time you will replace the mouth piece
of your phone.
I am
guessing you accidentally dropped your phone or hit it on something and
that has made the mouthpiece to shift from its original position
What
you should do is to open your phone,look at the bottom part of the
phone,that is the part you normally speak through,you will see the
mouth piece.
Try shifting it so it aligns with the mouthpiece hole on the case of your phone.
Fix the casing back properly then test if it works, i am sure it will
If you cant do this yourself please give it to somebody with experience to do it for you
I am guessing you accidentally dropped your phone or hit it on something and that has made the mouthpiece to shift from its original position
What you should do is to open your phone,look at the bottom part of the phone,that is the part you normally speak through,you will see the mouth piece.
