Make sure the telephone wire is
plugged into the line jack (not ext jack) and should go straight to the wall, without
splitters or extensions. If you still cannot send a fax, try another
wire or jack
Your MFC displays the date and time and if you set up the Station ID it prints on every fax you send. If there is a power failure, you may have to reset the date and time. All other settings will not be affected. 1 Press Menu, 0, 2. 2 Enter the last two digits of the year. Press Set. 3 Enter two digits for the month. Press Set. (For example, enter 09 for September, or 10 for October.) 4 Enter two digits for the day. Press Set. (For example, enter 06 for 6th.) 5 Enter the time in 24-Hour format. Press Set. (For example, enter 15:25 for 3:25 P.M.) 6 Press Stop/Exit. The LCD now shows the date and time whenever the MFC is in Standby mode.
The easy way to reset the machine is to power it off for a period of time. Say overnight will allow the battery back up on the board to run out and the machine to loose its memory.
Here's the manual. Look at page 6-8. That tells how to turn on real-time transmission. You just need to do the same thing, except switch it to off when you get to that step.
http://www.brother.ca/en/products/pdf/manuals/MFC8220-UG.pdf
yes i have dail tone
Do you have a dial tone? Check withe the handset.
