Question about LG GM200 Cell Phone
The phone can't send any files through bluetooth. it can only recieve files. I already upgraded the software, but the problem is still there
Posted by vigneshanil0 on
CARLOS R SOUZA JR
    President:
  • 1,118 Answers
In order to send files to another device through bluetooth, go to 'Menu > My Stuff' and navigate to the file you want to send. Then, go to 'Options > Send via > Bluetooth'. When the file browser returns to the list, press 'Done'. You'll be offered a list of paired devices. Select the one you want to receive the file, and you should be good to go.
Hope it works for you.
Cheers! Carlos
Posted on May 08, 2010
I am not able to connect my bluetooth device with others n not able to share information with other via bluetooth
Hello
First ensure that your bluetooth is on and visible to everyone
When you want to send a file and scroll to "Send via Bluetooth" on your phone, your device list may come up empty. Sometimes this can be resolved by physically moving the devices closer together. The maximum distance between devices is 30 feet -- less if there is an obstacle blocking the signal.
check to see if the receiving device expects a security code before receiving transmissions. Some phones have security restrictions to prevent hacks.
Most Bluetooth-equipped devices come with a factory-set name. Change your device settings so that all your electronics have unique monikers. There are still some compatibility issues among Bluetooth devices, too. If you can send a file from your phone to your computer, odds are everything is working properly, but you have compatibility issues with the receiving device. Check the manufacturer's website for software updates for your phone, or visit a service center. But be careful: New phone software that updates the operating system can erase all your phone information.
Oct 02, 2010 | Ericsson Cell Phones
Hi, i have a storm 9500. my problem is that i cant recieve any data via bluetooth. it was working properly but since i upgraded my software , it aint working anymore.. i can stil send but cant receive via...
When you open Manage connections in the MENU thers is a option SET UP BLUETOOTH then search for the open devices which are visible then pair it by using the sme pass key then when your done with pairing you go to MEDIA then when you open media and then press BB button which is the 2nd button from botton of the screen their you will see an option Recieve using Bluetooth and the screen displays waiting for connection and then you will be able to recieve any file video or piture .
Sep 10, 2010 | RIM Research In Motion Blackberry Storm...
My bluetooth not responding to any process recived or sent
to recieve anything via bluetooth on blackberry phones you must first choose the file of type..eg.if you want to recieve a picture from someone, go to media-pictures-blackberry button-recieve file. To send you must be paired and have it switched on perm.
Sep 07, 2010 | RIM BlackBerry Pearl 8120 Cellular Phone
Nokia 5200 Bluetooth problem
check your phone memory.That should be greater than the size of the file that you are trying to transfer..check which is your memory in use also.If memory is available check the phone visibility and try to pair the device and send..it will get clear....Hope this will help you...
Nov 21, 2009 | Nokia 5200 Cellular Phone
8130 blackberry
go to media file and depending on what type of file (ringtones,pics etc) you can choose to recieve it bluetooth
Sep 05, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I cant recive the files from my bluetooth
welll turn it off and then turn it on and change the settings
Jul 23, 2009 | Sony Ericsson K550i Cellular Phone
Whats the infered for
its for sending and recieving files . for example if the other phone , device or laptop also have infrared than u can recieve and send file to that device . its work same as bluetooth but the real difference is between ther distance infrared only send and recieve data on range of 1 metre but bluetooth can send and recieve data upto 100 meter .thanks and take care of urself bye.
May 09, 2009 | Cell Phones
I want to use my iphone 3g bluetooth in every situation
You can't send and receive files with the iPhone's bluetooth. Version 3 of their firmware will supposedly provide this functionality, but only on the iPhone 3G. (2G models don't have the necessary hardware)
As for the hands-free car setup, that should work just fine. It's a matter of pairing the two devices together.
Apr 20, 2009 | Apple iPhone 3G
Bluetooth problems
wow, will you should buy a new phone...or hopefully you have to format the music files to .mp3...try deleteing the bluetooth contacts that you have paired to your device that may also help
Jan 15, 2008 | Motorola Mobility RAZR V3
Bluetooth
restore ur handset.and try via diff handset for confirmation purposes.
Oct 23, 2007 | Nokia N95 Cellular Phone
LG GM200 Cell Phone Logo
51 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
William Norris
William Norris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
