Place front end on jacks or ramps. I belive there is a lower plastic guard that protects the serpintine belt from water splash ( I know the 96's did not have it but uncertain about 1997, is so remove it) Drain radiator/cooling system. The serpintine belt will have to be removed, you'll need to use a box end wrend on the tensioner to remove pressure from belt, it will fight you but she will go. Next remove bolts that hold pulley on to water pump shaft (I believe there are three, all 10MM) next remove all of the bolts that hold the water pump on, I belive there are either 5 or 6, either 8 or 10MM. Clean surface where pump applies to, be certain to use new o-ring, should be with water pump. Reassemble in reverse, install new serpentine belt and use proper 50/50 mix of radiator fluid and water. Start engine, let it come to heat and check for leaks, keep eye on temp gage to be certain things are ok.
I hope this may have assisted you,
Tom
