Question about Pure Digital Flip Video Ultra Camcorder
My lens is cracked on my flip cam, how do i fix it?
Anonymous
  • 3 Answers
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Posted on Apr 15, 2010
Testimonial: "Great tip! I took an xacto knife and popped out the broken glass! "
  • Anonymous Jul 06, 2010
    I took mine to a watch repair shop and they found a watch crystal that fit perfectly.
Anonymous
    New Friend:
  • 5 Answers
EBay has replacement glass lens that work great for $15.99 and they come with a protective film... I suggest to check it out if your lens is cracked or scratched.
Posted on Sep 05, 2010
Anonymous
    New Friend:
What type of lens did you use to replace it once you popped out the broken lens? I have the same problem, broken lens and my husband popped it out and says if I find a replacement lens he will glue it on.
Posted on Jul 06, 2010
My sony handy cam shakes really bad when I zoom...It's not caused by me because it still does it even on a tripod...Is something loose?...any info on how to fix this would be greatly appreciated
Inside your camera there is mechanical movement when you zoom. There is a motor that turns a wheel is connected to a belt with teeth that goes to your lens. this moves the lens in and out. If a screw on this assembly is loose then anything of that sort can happen. You to have the lens assembly opened professionally then check if the belt and motor are still running properly and if the assembly is not loose. You can tighten the screws or if something is cracked you can use superglue to join it together. Using it like that will make the situation worse and it might stop working.
Nov 15, 2011 | Sony Handycam CCD-TRV108 Camcorder
My son dropped our flip camcorder and the lens is cracked
[eBay] has replacement lens for the Flip Video. $15.99 free shipping. Also comes with protective lens covers.
Jan 03, 2010 | Pure Digital Flip Video Ultra Camcorder
Broken lens
Had a broken lens as well. As you're probably aware it's not really a lens but a protector like a watch crystal. So I went to a jeweler who said, "Oh I don't know, it's not a watch. Bla bla bla." I said I'm not going to hold you accountable. He said fine. He fixed it easily. $20.
Oct 01, 2009 | Pure Digital Flip Video Camcorder
My flip video has a broken lens. Where can I get this repaired?
If you've never received an answer to this, I have a Flip UltraHD that had the same problem. I took pictures all along the way of fixing it. Let me know if you'd like to see how to fix it! Not hard at all if you're GENTLE!
Shame on Flip for not making this simpler!
Sep 24, 2009 | Pure Digital Flip Video Camcorder
The lens cracked. The camera still works but the picture shows cracks. Is it possible to repair it?
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
Jul 12, 2009 | Pure Digital Flip Video Ultra Camcorder
Casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Jul 05, 2009 | Casio Exilim EX-Z77 Digital Camera
Lens jams when extending or retracting
This is either due to a cracked internal roller or a cracked/broken internal cam. The lens will have to be sent to Tamron for repair.
Apr 12, 2009 | Tamron 28-300mm f/3.5-6.3 Minolta Mount...
Jammed lens and cracked led kodak m1000
Is this camera around $175.00 to $200.00? You can get an estimate for repair if you want, however, a repair person will probably charge for an estimate. Repairs on Digi cams are expensive, so I'll have to advise you to replace it. Sorry, I couldn't
give you a nicer answer.
Thank you for using Fix Ya
Aug 16, 2008 | Cameras
Lens Stuck
in this task you may contact a professional technician or what so ever. that has have an idea about the digicam. i seem in the picture you shown. its like a crack in the thread of your lens. but if you have a idea on this. you may open it by take out 5 - 6 screw. and slowly remove the cover. after you seem the outter of your lens there's a mecahnical inside. fix by removing the lens into your cam. if youve seem the problem fix it. if you did not understand this. you may contact some experts about this.
tnx.
Jan 30, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Pure Digital Flip Video Ultra Camcorder Logo
982 people viewed this question
Top Pure Digital Video Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
robert faass
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
