Does it agitate?
Does it spin by hand?
Does it agitate if you advance the timer?
Could be the lid switch (#1).
Could be a broken motor/pump coupling.
Could be the timer.
Look under the washer for bits of black rubber (indicating the coupling insert has failed.
If the coupling is in place, next, bypass the lid switch temporarily to see if you can trick the unit to think the door is closed (safety mechanism)
if the lid switch is bypassed, the coupling is good, the timer is faulty.
All items in this answer can be found at repairclinic.com and enter your model # in the box.
If you hear the motor trying to spin - the most common problem in this direct drive unit is the rubber coupling element and broken coupling teeth.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
