Question about iLO 3200 32 in. LCD Television
My ILO 27" screen tv has white lines at the top of the picture and it seems like it's showing an upside down version of the top of the screen. Can it be fixed?
    New Friend:
  • 19 Answers
This is called "vertical foldover" and it is usually an easy repair for any TV tech.
Posted on Apr 20, 2010
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
WHITE LINES
i have the same problem
Nov 07, 2008 | iLO 3200 32 in. LCD Television
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Nov 02, 2007 | iLO 2600 Television
Toshiba 27" standard def. TV
white narrow lines mean at the top of the screen called top retrace lines it is due to vertival section. any high value elec. cap might be defective.
Sep 13, 2007 | Toshiba 27A34 27" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
JVC 27"
Repaiur or replacement? It's Your call! If you know Solid State repairs, then worth a try. Most likely a bad Electrolytic capacitor in the Vertical Oscillator / Output section. Do not waste time identifying faulty one, but change all at one go. Even if one is faulty, the others must have started drying up, and will cause problems in the future.Remember "An Ounce of prevention is better than......"
Oct 01, 2006 | JVC AV-27D303 27" TV
Top section of the picture gets reversed and compressed
Dear simon, Seems like a simple problem. In all likelihood, one of the Electrolytic Capacitors in the vertical Output stages has failed.It could also be a cold / dry solder, as symptoms seem to disappear when you tap the set. But, do not try anything thing at home. A proffessional Techie should fix it up in 15-20 mins. Definitely worth the spend.
Aug 02, 2006 | JVC AV-27230 27" TV
iLO 3200 32 in. LCD Television Logo
245 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
