1/turning the unit on the screen or panel is all white
Turning the unit on screen or panel is all white with sound 2/other times it has multi coloured panel showing only pixels in a line formate with sound 3/and 3rd the unit is in a coloured in a negative like a negative picture
the unit 12 18mths young??
Dave
Hi, have you activated the Reverse colours function? Go to Settings / General / Accessibility / Invert Colours
did you drop it by any chance? My boy dropped his and we got the dreaded black screen one time - then we gave it the hard smack treatment on the backside to release the jammed accelerometer - this worked perfectly the 1st time it happened, the 2nd time he dropped it we reverted to strange black and white colours, the smacking continued, and the colours came back.
try reverting to vga mode http://www.playtool.com/pages/safemode/safemode.html
tap f8 a couple of times after bios shows, then select vga mode in the list
if that works then you can change to a different resolution in display
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You,
Arjun.
Wiring relays and connections – all modelsRelays (typical)
1 Vacant 2 Intake manifold preheating relay (carburettor models) or fuel pump relay (injection models) 3 Seat belt warning system relay 4 Gearshift indicator control unit 5 Air conditioner relay 6 Dual tone horn relay 7 Relay for foglights and rear foglight 8 Relief relay for X contact 10 Intermittent wash/wipe relay 11 Rear window wiper relay 12 Turn signal flasher or trailer towing warning relay 13 Seat belt warning system (interlock) or rear window, driving lights and oil pressure warning relay 14 Window lift or seat belt warning system relay 15 Headlight washer relay 16 Control unit for idling speed increase 17 Fuse for rear foglight 18 Control unit for coolant shortage indicator 19 Thermo fuse for window lifters 20 Switch unit for heated driver’s seat 21 Switch unit for heated passenger’s seat 22 Switch unit for overrun cut-off 23 Vacant 24 Vacant Relays are symbolised as a number in a black box Not all relays are fitted to all models Connections A Multi-pin connector (blue) for dash panel loom B Multi-pin connector (red) for dash panel loom C Multi-pin connector (yellow) for engine compartment loom left D Multi-pin connector (white) for engine compartment loom right E Multi-pin connector (black) for rear wiring loom G Single connector H Multi-pin connector (brown) for air conditioner or wiring loom K Multi-pin connector (transparent) for seat belt warning system loom L Multi-pin connector (black) for lighting switch terminal 56 and dip and flasher switch terminal 56b (carburettor models) or multi-pin connector (grey) for dual tone horn (injection models) M Multi-pin connector (black) for lighting switch terminal 56 and dip and flasher switch terminal 56b (injection models) N Single connector for separate fuse (manifold heater element) P Single connector (terminal 30) R Not in use Fuse colours Blue 5A Green 30A Red 10A Yellow 20A
If it does it only on HDMI, then, the problem is the Main PCB. The HDMI cables are to heavy for flat panel sets.
If the problem happens on just one input such as component and analog, then the problem is more than likely the source.
Does the problem appear on DVD, but not the cable/satelite?
If the problem appears on every input, then the problem is the main PCB.
Hope this helps.
