Question about Pioneer Djm-909 DJ Performance Mixer with Effects System
Can i connect 2 amps on djm 3000? If yes how?
Can i connect 2 amps on djm 3000 mixer ? If yes how?
Posted by momalkha on
Anonymous
    New Friend:
Actually you can direct connect Three Amps from this particular mixer without needing to split the cables with Y shape connection splitters etc... The Pioneer DJM909 has TWO Master Outs and One Booth Out. One of the Masters Takes XLR Connections the Other Matsre and The Booth/Session out both take RCA connections.
I use the XLR outs to go directly into my Self Powered JBL Subwoofers and the RCA Master to go into an AMP to power my regular 3Way Speakers and the Booth out to a separate amp to power my monitors. I looked at the diagram of the 3000 and it too has the same three outputs so you too can easilly connect Three Amplifiers to your mixer.
- DJ Emir
Posted on Sep 19, 2010
Anonymous
    New Friend:
  • 135 Answers
You can connect one amp to the "master" output and the other to the "booth" output. You would then be able to adjust the volume of the amps independantly using the master and booth controls.
Hope this helps.
http://www.technicsdjuk.com/
http://stores.ebay.co.uk/methleykev
Posted on Jul 12, 2010
Morne Olivier
    Guru:
  • 257 Answers
I currently have 3 amps connected to one mixer. All you need is to check where your amp is currently plugged into the mixer. now get yourself 2x RCA two way splitters at your local music shop (ie. One male to 2 female)split the channels from your mixer input, and an extra amp can be plugged into the spare plugs
Posted on Jun 08, 2010
2 Related Answers
Anonymous
  • 135 Answers
SOURCE: mixer probs
I have the full manual, email me
[email protected]
Posted on Jul 05, 2010
Anonymous
  • 135 Answers
SOURCE: hello. have a djm-909. CH-2 just stopped working.
There are solid state "N" type fuses / circuit protectors soldered to the circuit board.
Hope this helps.
Am getting electric shocks why?
One of your wires is faulty. there is a open ground. Check all your wires, or, one of your devices has a dead ground short.
Apr 04, 2015 | Pioneer DJM-700 Standard Mid-Range...
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
How do i connect a pioneer djm 500 mixer to a dbx 215 equalizer
You can use either (2) XLR mic cables or (2) balanced 1/4" cables running from the Master Out of the djm 500 to the dbx 215. Then you connect your amp to the outputs of the dbx 215.
Joey Clay
Oct 14, 2009 | Audio Players & Recorders
HOW DO I CONNECT A KAOSS PAD MINI TO MY PIONEER DJM 500 MIXER
Try running it in your FX loop ( out of the mixer into the Kaos, out of the kaos back into the mixxer or out of the mixer into the kaos and out of the kaos into your amp.
Jul 08, 2009 | Korg Mini Kp Kaoss Pad
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
DJM 500 & 2 1200mkIIs -- Very Low Sound With Multiple Speaker Sys
are you sure you have your tt's plugged into the phono line with the master booth knob turned up? Check the mixer too cuz the techs should be square.
Jan 15, 2009 | Pioneer DJm500 Professional DJ Mixer...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer Djm-909 DJ Performance Mixer with Effects System Logo
242 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
