Question about Frigidaire FDE546RE Dryer
Dryer runs but no heat. What should be checked or replaced?
Anonymous
    Sergeant:
  • 256 Answers
It appears that your dryer is an electric one. So, you need at least 208 - 220 volts for the heat element to come on. If you are o.k. at the circuit breaker and at the wall outlet with the appropriate voltage, then your problem could be a heat element, thermostat, timer, etc. on the dryer. Contact an appliance service company.
Posted on Apr 14, 2010
Testimonial: "Turned out to be the circuit breaker, but thank you!"
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Dryer runs but won't heat. I need to check the
there is no fuse, you need to replace heating element
Oct 24, 2010 | Frigidaire GLEQ332A Electric Dryer
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
Dryer won't heat
you spent a lot for a timer when you needed to check your heating. check the heating element, the high limit, and the thermofuse
Sep 25, 2009 | Whirlpool LER5636P Electric Dryer
No heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 23, 2009 | Whirlpool LER5636P Electric Dryer
INGLIS DRYER MODEL IP82000 RUNNING BUT NO HEAT.
2. Heating element
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.(((((Most common issue)))))
Aug 04, 2009 | Whirlpool Inglis IP8200 Dryer
Ihave a kirkland signature dryer model#seds800jqo dryer runs but
2. Heating element
3. Thermal fuse
Jul 23, 2009 | GE Profile DPXH46EA Electric Dryer
Dyrer runs no heat cannot locate fuses
2. Heating element
3. Thermal fuse
Jul 20, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
2. Heating element
3. Thermal fuse
Jun 02, 2009 | Whirlpool Dryers
Heating Element
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 27, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
82 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
