Question about Whirlpool GEW9200L Electric Dryer
Burning smell when on.
We checked the lint tray first...burning smell when dryer is running. It is 5 years old. It was only on for two loads during the day.
Posted by a_mcara on
Anonymous
    Sergeant:
  • 256 Answers
You could have an issue with lint that has accumulated surrounding the heat element, motor, etc., or there may be some faulty wiring. Contact an appliance service company.
Posted on Apr 14, 2010
Burning smell in dryer
Have you checked the motor? Plenty of lint and dust gets indie it. If you can remove if and use compressed air to blow it out. Also don't overlook the fact all the spade connectors will also collect lots of lint and dust which is quite flammable. Also check the tensioner and guide wheel they get pretty dirty and when they heat up the lint can start buring.
Aug 11, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Had "burning" smell during dryer
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Feb 27, 2011 | GE Dryers
It is taking over 2 hours to dry a load of clothes. I stopped the cycle and opened the door to check the clothes. The dryer smelled like something was burning but no visible smoke. This is a fairly new...
Sounds like the vent is clogged with lint. You should have the vent cleaned once a year to keep the appliance operating properly. Also, make sure there are no kinks in the vent line.
liberty
Jan 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
KENMORE DRYER
the only thing that can burn in a drier is lint most of the time if lints building up in a drier depending on age its because of poor venting if the drier heats but it takes longer than an hour to dry clothes you have a vent restriction but every few years you should take it appart and clean it out now kenmores drums run on rubber wheels and like a car they get flat spots in them so they roar and bump when they first start but should get quiter as you run more loads during the day
Dec 29, 2007 | Kenmore 63942 Dryer
Whirlpool GEW9200L Electric Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
John Tripp
John Tripp
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
