Oil Pan - Removal & Installation3.7L, 4.7L And 5.7L Engines
To install:
Negative battery cable
Structural cover
Front crossmember
NOTE
Don-t pry on the pan. The gasket is integral with the windage
tray, and doesn-t come out with the pan.
NOTE
The double ended studs must be installed in their original
locations.
Pan bolts and studs
Pan
Oil pan gasket
Oil pan. Tighten the bolts, in sequence, to 105 inch lbs. (12 Nm).
Front crossmember
Structural cover
Fig. Oil pan bolt torque sequence-3.7L engine
Fig. Oil pan mounting bolt tighteniI need to replace the oil pan gasket on a 03 dodge - f5a0196.jpg-4.7L engine
Fig. Oil pan alignment dowel placement-3.9L engine shown
Hope helped; TY for using Fixya (remember comment and rated this post).
Yes its that simple once you remove the pan
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Car oil leak?
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
Car oil leak?
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
Car oil leak?
This will help.
Thanks.
