The only other light I'm aware of is the light in the back of the machine attached to the radio frequency ionizer. This light lets you know that both of the ionizers including the needle point ionizer are working. When the light is off, it means the ionizers need cleaning or service. When I clean my machines, I always clean off both ionizers w/ a 50/50 solution of Ammonia w/ a paper towel. I do this the same time I clean the ozone plate. If you're machine is still under the 3 year warranty, you can send it back to be fixed for no charge except shipping. I hope this helps.
If you're talking about those little plastic tabs at the bottom, they aren't important. Their job is to wipe the ionizing wires when you take the grid out or replace it.
I
have the same problem and haven't been able to fix it.However, others have had the same problem and
have posted their solutions.The
sizzling sound is caused by electrical arching between the plates and one or
both of the two tungsten wires that are run parallel to the plates (if you turn
off all the lights and wait for your eyes to adjust to the dark before turning
on the Ionic Breeze, it's a pretty cool light show!)Here are things found by others to cause the
arching and what they did to fix the problem:
--dirt, lint, or tiny hairs
stuck somewhere (usually towards the top or bottom of the plates or wire,
and maybe in the grid contact points).Clean it better.Using
canned air can help blow out the problem.
--water droplets.Make certain there is no moisture
anywhere when you put the grid (plates) back in.Using canned air can help dry hard to
reach areas.
--burn marks or melted
plastic.These indicates a short
circuit.Says dnewcombe1: "There is a
feeler bracket that guides the two rear thin wires while the cartridge is
being inserted. This "feeler" can melt and become disarranged."You can't fix this issue.
--build up on the ionizing
wires.Clean them.It's hard.I took mine apart and used steel wool.
Ionic Breeze machines are no longer being supported. Sharper Image recalled the product several months ago after it was proven by Consumer Reports and the EPA that the product wasn't cleaning the air and can be harmful to use. Sharper Image took legal action and lost.
The Consumer Product Safety Comission is going to make a decision on all ionizers by the end of the year. It's looking like all ionizers will no longer be sold in the U.S. regardless of who makes them.
Sharper Image Ionizers are no longer supported because they have recalled since they were proven to be innefective for cleaning the air and can harm people with breathing problems.
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
