Question about AT&T Motorola RAZR V3 Cell Phone - Black
My screen has flipped upside down how can I get flipped back over
Posted by Mary Couch on
Plays back on lcd screen upside down at times
When the viewport is completely flipped around so you can see it when you are looking at the lens, it automatically flips it upside down so it is right side up to the viewer. Make sure it is locked into the correct position to prevent this from happening.
Hope this helps
Dec 05, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
My kids flipped the screen upside down and I can't flip it back. When you are looking at the screen everything is upside down
LOL, LOL -- thats is so funny !
this will help
Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down.
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW
please issue positive feedback for me
Oct 20, 2010 | Dell Latitude D510 Notebook
Screen upside down
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW.
You can also try CTRL-SHIFT and then “r” … this works for some Dell configurations
This problem can also be solve in some PC using the below technique.
In Control Panel>Display>Settings tab>Advanced button, look for settings relating to display or screen position.
Newer video cards have the capability to flip the display 90 and 180 degrees for use with LCD screens that can be rotated.
If the problem still persist, Start you PC with F8 key press, select "Last known good configuration that works"
it will most probably solve the problem.
Jan 20, 2010 | ASUS Eee PC 1000H Laptop
Image on monitor is upside down!
most the time pressing CTRL ALT UP ARROW together will flip the monitor back right side up
CTRL ALT DOWN ARROW will flip the screen upside down
Dec 05, 2009 | Acer Computers & Internet
UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Mar 31, 2009 | Motorola Mobility i880 Cellular Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Picture reversed and upside down on screen????????
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
May 02, 2007 | Toshiba SD-P1200 Portable DVD Player
AT&T Motorola RAZR V3 Cell Phone - Black Logo
174 people viewed this question
Top AT&T Cell Phones Experts
Ekse
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
