Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
Posted on Apr 14, 2010
Bosch Classixx Dishwasher -check water light keeps coming on
I have a Bosch Classixx Dishwasher, the slim line version. Moved it from one house to another and when I try to use it the Check Water light comes on and it just hums. Any thoughts?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 27, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2432
Points
Thanks i empied my dish wisher old water then it word again thanks Neil Spink
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
1helpful
There should be a plastic cover on the bottom, the removal of this gains access to most of the seviceable parts. beware of water spillage when you tip machine into its back!. Good Luck
No water coming into dishwasher
Check inlet water connection and the strainer attached to the machine.
clean the strainer and try. If the same condition remains check the inlet valve and its operation. Inlet valve inside the machine.
Water not draining properly - leaving residue in bottom
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
1helpful
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
1helpful
2answers
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
6helpful
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Check water
very possibly you have a faulty water flow switch. If a certain flowrate is not detected within a certain time, that light would come on
Bosch Classixx Electronic not working
could be faulty door switch check that either board may be at fault but before this hapens is there power at board if not you may have had a flood internally tripping flood switch
3helpful
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
