Alesis M1-Active MkII Main / Stereo Speaker Logo
Question about Alesis M1-Active MkII Main / Stereo Speaker
Alesis M1 active 620 woofer problem
Pleae help. I bought a pair of Alesis M1 active 620 studion monitor speaker. I have two problems (but only with the one of the two speakers...the other seems perfect)
1. By the low frequencies e.g.: subs the woofer buzzes, its very disturbing, because its pretty loud. And I don't have to listen to music loud to get this problem, it exists also by low volume level.
2. This is the bigger problem. By listening music sometimes the woofer mutes, so... no sound come out of it, and after roughly 5-6 seconds the sound comes back. Then its ok for a while, and after about 2-3 minutes the woofer mutes again, then after 5-6 seconds the sound comes back...and so on...
What can be the routecause by this two problem?
(Additional information: I use XLR cables, passive volume contorl, the speaker gain are set not more than 75% and the volume control was never set more than 50%. I changed the cables, supposing that is the problem, but didn't help)
Posted by m_pulse on
Grubhead
  • Alesis Master
  • 5,750 Answers
There clearly is a fault in the sub's amp section. It's probably the main part that does most of the work. It will need to be replaced.
Posted on Mar 08, 2017
4 Related Answers
Anonymous
  • 15 Answers
SOURCE: alesis 620 m1 active studio monitors sound cutting out
It could be a power problem, unless you have blown the driver ?, carefully pull out the power supply board, and look to see if anything looks melted, burned, or capacitors popped etc. Be carefull though as I do not want to be responsible if you get an electric shock, etc. preferably look and dont touch, just use common sense ;)
Posted on Jun 02, 2009
shaqsatin
  • 18 Answers
SOURCE: woofer doesn't work
sounds like the voice coil could be open or damaged. the woofer can be reconed. reconing replaces all the moving parts in the speaker frame returning to new condition in most cases.
[email protected]
Posted on Jun 25, 2009
Anonymous
SOURCE: my alesis m1 active 620 monitors blue lite keeps
Thanks for following up...I took it to get fixed..$150.00 later it works..
Posted on Oct 08, 2009
Anonymous
  • 71 Answers
SOURCE: Alesis M1 Active MKII Don't get power / Blue light is off
Sure they don't have power? Light breaks all the time on those things. If no power still, open it up and find out if there are any loose connections from the power leads. Bad power cable?
Posted on Mar 16, 2010
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
1helpful
Alesis M1 Active 620 studio monitor cutting out
I see from the manual there are several controls on the speaker that could affect the sound in the way you describe (gain, hi- and mid-boost, acoustic space). Why don't you compare the actions of each control with the working speaker as the standard and a test tone or FM noise as the source? It might help you to identify a specific internal function that has changed. After that, someone's going to have to crack it open and do surgery.
You might also try using the opposite input (TRS vs XLR) than the one you're using. It might reveal something.
My alesis m1 active 620 monitors blue lite keeps blinking and duz not work
Woofer doesn't work
[email protected]
Alesis 620 m1 active studio monitors sound cutting out
1helpful
2answers
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
