If it tells you there is no compatible access point in range, then you are not near an access point. The liberty card must require you to be connected to the internet, and if you have no wireless internet in your residence, then it will not work. An easy fix is to head to a common fast food restaurant, most nowadays offer free Wi-Fi.
Go away from your brothers DS. Go into another room and turn off the DS and turn it back on and then see if it finds the access point. If it doesn't and you know your wireless is working then that means the wi-fi card is bad and needs to be replaced.
You can boost the signal range of a WiFi computer network in several ways:
Answer:
reposition your router
(or access point) to avoid obstructions and radio interference. Both
reduce the range of WiFi network equipment. Common sources of
interference in residences include brick or plaster walls, microwave
ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
add another access point (or router). Large residences
typically require no more than two APs, whereas businesses may employ
dozens of APs. In a home, this option requires connecting your primary
wireless router (access point) to the second one with Ethernet cable;
home wireless routers and/or APs don't normally communicate with each
other directly.
add a bi-directional WiFi signal amplifier to wireless
devices as needed. A WiFi signal amplifier (sometimes called "signal
booster") attaches to a router, access point or Wi-Fi client at the
place where the antenna connects. Bi-directional antennas amplify the
wireless signal in both transmit and receive directions. These should
be used as WiFi transmissions are two-way radio communications.
add a WiFi repeater. A wireless repeater
is a stand-alone unit positioned within range of a wireless router
(access point). Repeaters (sometimes called "range expanders") serve as
a two-way relay station for WiFi signals. Clients too far away from the
original router / AP can instead associate with the WLAN through the
repeater.
