Question about Haier BC112G Wine Cooler
It seems like my compressor is not working. My Temperature is up 84 degrees F!
Posted by mgelizalde on
Anonymous
    Sergeant:
  • 256 Answers
Your compressor should make a slight buzzing sound if working. Touch it to see if you feel vibration. Otherwise, your issue may be the compressor or components attached to compressor (e.g.: relay, overload or capacitor (if applicable).
Posted on Apr 14, 2010
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Fridge showing incorrect temperature
The temperature sensor might need to be replaced, however, if the compressor is never shutting off, then the contents of the refrigerator will freeze and the compressor will "freeze up" too.
Buy a refrigerator/freezer thermometer to determine the actual temperature.
Dec 15, 2015 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
My A/C is operating outside the house, but there is no cool air inside the house. We set the temperature onto 84 F Degree, however, the inside-house temperature has already reached 88 F Degree. Can you...
With such limited information the following is the most likely problem.
1. The fan outside is running but the compressor is not.
2. The inside air handler blower fan is not working.
3. The system is froze up and not allowing any cold air to come out of the vents.
Hope this helps
Sep 19, 2011 | Honeywell Heating & Cooling
Have a brand new Master Temp 400K Propane with an Intellitouch and the heater shuts off at 84 degrees. Do I need to set a max temperature from the heater control panel?
If this heater has pool mode and spa mode as an option, and you need the water higher than 84 degrees, you must set it to spa mode even if it is a pool. As a regulation, these heaters come pre-set to max out at 84 degrees as a safety feature. However, in spa mode it can reach 104degrees.
Jan 11, 2011 | Pentair Mastertemp Heater
Temperature is at 51 degrees. Door has been open and shut all day but the temperature shouldn't be this high and it doesn't seem to be going down.
check the evaporator fan and condensor fan. condensor coil clean. compressor warm.how much frost build up . if frost build block air way, i am sure the problem is heatelement or defrost thermostat. good luck.if the compressor not work . need to check the relay
Jan 10, 2011 | Sub-Zero 650 / O Bottom Freezer...
Amcor 10,000BTU set at 64 degrees - - temperature of air coming out of unit is 72 degrees. In one and half hour set at 64 degrees the room temp only went from 90 degrees to 84 degrees. Recommendations?...
I am not sure, i have a similiar unit that is brand new, seems like a faulty mechanism from the maker, it starts cold for about 2-3 minutes and then shuts down condenser and blows hot air repeating this cycle. I don't believe it ias a recharge, just a faulty machine
Jul 15, 2010 | Amcor PLM-14000E Portable Air Conditioner
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Refrigerator temperature climbs and takes too long to recover.
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Send this information so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Refrigerators
Haier BC112G Wine Cooler Logo
417 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Haier Furniture Expert? Answer questions, earn points and help others
