Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I NEED TO RESET THE MASTER CODE ON THE GORDON DIGITAL SAFE BUT I DO NOT KNOW THE OLD MASTER CODE
Posted by rdb4 on
Prakash Timilsina
  • 107 Answers
Hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Posted on May 08, 2010
How do I change the combination on a door key safe
Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
Feb 01, 2015 | Home Security
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Jul 04, 2014 | Safe International Digital Electronic Safe...
Gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
Feb 13, 2010 | Safe International Digital Electronic Safe...
I have a gordon digital electronic safe i have forgotten pin can you help?
put the thing in your lap...bump the unit up and down while trying to turn the handle!
if the safe isnt mounted, you can use a long screwdriver to reach through the mounting holes on the back to push the code reset button!
Dec 16, 2009 | Safe International Digital Electronic Safe...
Gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Oct 07, 2009 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Resetting code
Go to harborfreight.com; click on safes picture in the right column; then click on the safe that you have (#45891); then click on the instruction manual download icon at the bottom. This should solve all your problems.
Feb 16, 2009 | Safe International Digital Electronic Safe...
We have a Gordon Digital Electronic Safe sku#P45891 . The original pin code that we set it too is no longer working. We cannot get into the safe.
Put the safe on your lap and bounce it on your knees and keep tying to turn the knob I had it opened in less then 10 seconds! And the batteries were dead this really does work.
Jan 08, 2009 | Safe International Digital Electronic Safe...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
1,551 people viewed this question
Top Safe International Locks & Locksmithing Experts
Marvin
Marvin
john h
Sheldon Dedek
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
