Harley Davidson Road Tech HA90 MP3 Player Logo
Question about Harley Davidson Road Tech HA90 MP3 Player
I'm having problem with extream engine noise when i play the MP3 at a high volume, i don't notice any noise when i play the raido? I noticed that the lead going to the tuner has a three wires, one being a ground but it doesn't appear to be connected to the actual MP3 unit.
Posted by butler007413 on
Anonymous
    New Friend:
Yeah its burning up inside there switch it off and let it cool down
Posted on Apr 14, 2010
PS4 makes a high fan noise ?
It might be hot turn it off for at least an hour
My xp-50 is emitting a noise when the keys are pressed
If the level is very low, this is what is known as "digitizing noise".
The waveforms from synths being digital in nature, have sharp edges that are filtered. There is a fine line between filtering too much and too little.
There is ALSO the statistical noise that is present in electronic devices that you can notice when you turn the volume way up.
These are all NORMAL and the nature of the beasts.
Nov 28, 2009 • Music
Dont know how to skip song using headphone switch
okay if you notice, the headphone switch should have a + for increasing volume and a "-" for decreasing volume, in the middle is this groove part, which can be clicked aswell. Click the middle to play/pause. And double click it twice really fast to skip to the next song! Enjoy
1helpful
2answers
1993 buick century. motor noise stsrted coming out of speakers even with volume turned down.orig equipment
spark plugs been changed ? cheap plugs can cause this. spark plug wires ok? broken spark plug wire can cause this too or one just arcing to ground pass a loose boot raise hood after dark and run motor watch over all wires to see anything noticeable. Dont touch anything while running or things could go bad for you fast... some electric fan motor have a filter bolted to them this could be? does it vary with the engine? or stay one level? if all else fails it might be easyer to pick up a filter and install it in the power cable to your radio?
Stiletto2 sometimes has static while playing mp3's from exp. card
I also own a Stiletto 2 and I have noticed this same problem, but only when playing MP3's in my car. What I have found is that if the volume on the Stilletto is too high it creates distortion. The solution is to turn down the volume on the actual Stilletto and just use the volume on the car stereo. Problem solved everytime.
6helpful
3answers
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
1helpful
Volume settings on the Rio carbon
I'm afraid that there is not. What headphones are you using? I have found that when many people ask questions like that it is the headphones and not the player. People say that when using the 3.04 firmware (look in tips and tricks for this player), the volume is higher but I haven't noticed a difference personally.. When I put my Rio up to highest volume it would damage my hearing if I could put it up any higher and I can only hear people shouting when it is on full volume. Have you got another pair of headphones/earphones to try? You could buy some high ambient noise reduction earphones and this may help.
Hope this helps,
Mowcius
02 Dodge Durango Infinity (stock) system
this is not an easy diagnostic ,companies hide these amps in special places,amp needs to be check faulty fuse,ground or connections
Open Questions:
0answers
I have purchased a bike which had the Road tech HA90 MP3 / WMA Digital Music Player on it. Okay this has been an ordeal getting it to work. Cannot locate a instruction manual or the operation manual , I relied solely on Internet Search and mostly this web site. Here is what I have done. First used a 4G Micro SD Card - formatted to Fat 32 ...nothing...nothing seen or recognized... err no all sorts of errors...NEXT a friend has a player so rode over checked his card in my player and all is well ...HIS card is a 512 mb.IT WORKS PERFECT !!!! NO 512 SD Cards anywhere...the lowest 4GB. (Unless you order online) I have seen somewhere that someone wrote that 512 was the largest ...then another has wrote nothing over a 2G ...Now since I do not have a manual looked back at catalog page and it came with 64mb ..best of both worlds I have been able to by chance locate a 1GB SD Card locally . They no longer make cards under 4GB or stores do not carry around here, but can get on Amazon...Okay back to the issue. NOW TRYING THE 1GB card in Fat format / then reformat to FAT32 Tried it and the player recognizes the card tells me the number of songs I have on the card , is going thru the motion but NO SOUND.....now what???? I plan to get with friend and check info on his card regarding format etc. since it works, and order a 512 mb card ..HOWEVER Does anyone have the magic potion to offer advice on what to try next??? Thank you
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Top Harley Davidson Audio Players & Recorders Experts
Marvin
Marvin
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
