Question about Transcend T.sonic 850 MP3 Player
I couldn't delete song files from T.sonic 850. I connect it to my computer thru USB & when i delete the song files, it get duplicated & appear as 0MB. when i play the player, those songs appeared as not supported file. please help..
Posted by meck fa on
Michael Lei
    Master:
  • Transcend Master
  • 498 Answers
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
I couldn't delete song files from T.sonic 850. - view-the-downloading-videos-by-sorting-16-1srvjsc4otpwize3cqbthuvm-1-0_0.jpgFor more details, check: How to Delete Duplicate Songs
Posted on Apr 22, 2019
  • ADMIN Canada
    ADMIN Canada Apr 24, 2019
    Please don't resurrect old posts from 9 years ago! Spamming and personal promotion is not permitted on Fixya.
    Andrew - Fixya Moderator
mcline692
    New Friend:
I had this exact problem as well. The solution was to allow Windows to "Scan and Repair" the file system. The scan will likely detect all the duplicate 0-byte files created as you tried to delete files, and will remove these. In addition it should resolve the underlying problem such that you can now delete files normally without creating more of these 0-byte duplicates.
Posted on Feb 06, 2012
Have followed the instructions in the cd to delete music files. I get as far as pressing the red dot but don't then get ye/no to actually delete. advice on web was to click my computer and should get...
Hi frank aileen...
Try this easy way of deleting files you no longer want
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
This is a FREE answer, Please take time to rate me
Jun 01, 2011 | Transcend T.sonic 320 MP3 Player
When I connect my Transend Tsonic850 MP3 player to computer, it will recharge. But, it is not showing in system. I need to transfer new data to listen. Why it is not showing in system. How can I get it...
Your question appeared two times, I send my answer here also:
Try Powering it ON and OFF a few times, if this does
not correct the problem you can Reset the unit by pressing the "Reset" button for 3 to 5 seconds.
Is your T.sonic 850 properly connected to the USB port? If not, unplug it and plug it in again.
The MTP mode in the Settings menu should be set to "USB." In this mode, files
can be transferred by simply dragging them onto the T.sonic 850's Removable Disk drive letter.
You don't need any driver on PC in case of windows op.system.
If these don't help try study the user manual to find additional possibilities:
http://www.transcendusa.com/Support/DLCenter/Manual/TSXGMP850_EN_V10.pdf
gylacz
Mar 09, 2011 | Transcend T-Sonic 850 Digital Media...
Songs not opening
up date your player with latest firmware.visit.transcend.usa.com.
May 31, 2010 | Transcend T-Sonic 850 Digital Media...
T.sonic 850 not starting
press reset button & connect to the pc
Apr 12, 2010 | Transcend T.sonic 850 Digital Media Player
How to remove partition from my t.sonic 850
Generally there are no partitions on T Sonic.But if you have created them somehow,here's how to delete it.
1.Connect to windows XP 2.Right click "My Computer",click manage. 3.Goto storage>disk management 4.The partitions will be shown.Delete the partitions and create a new one.
Sep 18, 2009 | Transcend T.sonic 850 Digital Media Player
Transcend t.sonic850 player hangs when connected to the computer
plug in to computer
go to my computer
right click on drive
select format
turn off(after format unplug)
turn on =presto!
May 31, 2009 | Transcend T.sonic 850 Digital Media Player
TOO MANY DUPLICATE MUSIC FILES
As a matter of fact, you have several ways to remove duplicate songs from CDs or an external drive. The following post will show you three best ways to delete duplicate songs.
When you are going to remove duplicate songs, you can check out Leawo Tunes Cleaner. It is the Windows-based professional music cleanup software that could act as iPhone duplicate remover, local music remover, and iTunes duplicate remover to help you easily find and remove duplicate songs from iPhone, iPad, iPod, local folders and iTunes in clicks. And it helps you fix your iTunes music library and other music folders by adding song tags and removing duplicate songs. You need to download Leawo Tunes Cleaner ' Leawo Tunes Cleaner Mac and install it.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing ...
For more information, check: The Helpful Ways to Delete Duplicate Songs on iPhone
Mar 17, 2009 | Apple iTunes
The list of songs are not visible it says -'no files' but when connect with computer it shows all the files i have transcend tm 840 model
I have a similar problem since upgrading the firmware to version 1.4 on my T.sonic 850 (MP 850 since the f/w upgrade).
I guess the only real fix for me is to try to install an earlier firmware version until they issue an upgrade that fixes the bugs in version 1.4 firmware.
Until then I think I'll rather use a workaround that I discovered which is to go into another media option (that has at least one supported file on the player) in order to get to the directory/folder structure. Once I navigate about through a directory, say in search of a text or a picture file, I can then go back to the music option which will generally give me the "Not Support" error but I then have access to the directories and song files. Once I highlight a song and play it, everything seems to sort itself out.
Jan 17, 2009 | Transcend T-Sonic 840 MP3 Player
File format error - Transcend T.sonic 610(1gb)
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
Jan 29, 2008 | Transcend T.sonic 612 MP3 Player
Transcend T.sonic 850 MP3 Player Logo
120 people viewed this question
Top Transcend Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
k24674
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
