KitchenAid KEBC208 Electric Double Oven Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace the glass door on one of our double oven doors. Where can you buy the glass?
Anonymous
Level 3:
President:
  • Master 1,430 Answers
  • Posted on Apr 13, 2010
Anonymous
Master
Level 3:
President:
Answers
1430
Questions
Helped
308125
Points
4820
These are in stock at www.appliancehelponline.com just enter the complete model #. Installation instructions come with every part.
Where can I get my Frigidaire double oven door glass repaired
You can buy the new glass yourself and do it, as an easy task. Or you just called a Figidaire service tech. You will need the model number and you don't tell us :>D
https://www.google.com/search?q=frigidaire+gallery+oven+door+glass+replacement
videos for inner and outer door glass
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Miele H348B2 double oven, Need to source and replace outer glass in top oven. Having problems sourcing, any ideas? How easy it is to replace or do we need an engineer?
Hi Myri Mylonas-Prior,
I think the outer glass is just glass (where I HAVE found them... they WERE cheaper than the INNER GLASS)...
Your model number resolved to the UK... being here in the USA
I am pretty confident the differences ARE NOT insignificant...
All I'm seeing from here is inner door glass starting at £60...
I looked up OUR version of a Miele Double oven...
they are really quite NICE.
The inside glass is the critical one... Failing to find an "outer glass" Your LOCAL Parts/Spares retailers might be willing to suggest LOCAL GLASS shops.
(I'm just suggesting... never tried).
But also confident if you have a screw driver... you can do this!
and can construct a good search line Like:
Miele+H348B2+DOOR+GLASS
You should be able to locate a good part at a reasonable price... &
You should be well on your way...
The first URL I put below depicts a typical Whirlpool oven glass replacement VIDEO (not difficult... Certainly not as clean as they show).
Good luck.
http://www.appliancepartspros.com/whirlpool-inner-door-glass-74003645-ap4093513.html#autoplay
Miele H316B Cooker Oven Door Glass
H6780BP2 Miele 30 ContourLine Touch Convection Double Oven Black Glass...
Your search for door glass
Feb 07, 2016 • Miele Ovens
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Is it possible to clean between the two pieces of glass on the oven doors?
You would need to take the door apart, and even then the glass isn't really made to be taken apart. So it COULD be done, but it would be easier to buy new glass and replace it. It all depends on how much you want it to look clean.
22helpful
5answers
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
