Question about Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW
Freezer is on but no longer freezing. The freezer temperature is set at the coldest setting. Why is this happening?
Posted by iverym on
Anonymous
    Sergeant:
  • 256 Answers
You could have an issue with the temperature control, the compressor or refrigerant, or compressor attachments (e.g.: relay, overload or capacitor (if applicable). Contact an appliance service company.
Posted on Apr 14, 2010
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
FREEZER THERMOSTAT
Sounds like the thermostat is not working. Mechanical and electronic thermostats can go bad and cause the freezer to continue running no matter what setting is set on thermostat. When this happens the only setting that will work is turning the temperature setting to off. What is the model number on your freezer? Sea Breeze
Apr 03, 2013 | Frigidaire Freezers
Frigidaire freezer has ice accumulating and not freezing properly. Ice cream will not freeze.
Try turning the temperature control to off, unplug the electrical power cord from the power outlet, defrost the appliance, clean the condenser, plug the power cord into an electrical outlet, set the temperature control to a low setting, lay a thermometer in the freezer for a few hours and see what happens to the temperature in the machine.
Check the integrity of the seal of the door gasket by seeing how the door seal will hold a slip of paper in various locations along the freezer door gasket. A loose hold on the slip of paper shows an area where hot moist air can get into the freezer and cause ice build up.
Aug 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Freezer used as a frige?
it may be possible. Turn the temperature on the lowest setting and see what happens. If it still freezes everything up then it is not posible. If it doesn't freeze everything , then check the temperature with any temp probe. It should run at somewhere between 36 and 38 degrees. This is the normal cool setting on a refrigerator.
Nov 07, 2009 | Freezers
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW Logo
478 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Dennis Boxerman
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
