Panasonic Lumix DMC-TZ3 Digital Camera Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the maximum size to use for an sd card for lumix dmc tz3
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on Apr 14, 2010
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428961
Points
622693
The maximum size SD card you can use is 2GB because that is the maximum size SD card you can buy. Cards bigger than that are SDHC (Secure Digital High Capacity) cards. Fortunately the TZ3 is capable of using SDHC cards of 4GB and larger.
When we put an SD card in, onTV we get 3" grey
This is a tv setting problem, not a camera problem. If you have a widescreen tv, it can be set to several width aspects. Check your tv manual for instructions.
Lumix dmc-lz2 how high can the sd memory card go and which brand should I buy?
SD cards max out at 2GB. The manual states 1GB as the maximum size, but 1GB SD cards are getting very hard to find. You should be able to use a 2GB card.
2helpful
2answers
What size memory cards work with the Lumix DMCFZ20PP? I tried a 4GB and got a read error.
Hi
According to the information I have the maximum card size for the DMC-FZ20 is 1Gb SD.
Hope this helps
Dave
When I turn my camera on it reads "pictures will be recorded to built in memory". I have an SD ultra II 4.GB memory card inserted which I know isn't full. How do I get my camera to save to memory...
A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
I expect your camera just won't work with this kind of card. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written.
2answers
What is the maximum movie length on a Panasonic Lumix DMC TZ3 camera?
This depends on the memory you have available and your movie settings.
1helpful
Lumix DMC-TZ3
Memory card likely has temporary(needs formatting) or permanent problems(needs replacing, common for off branded china junk).
First format the mem card on your camera by pressing center Menu button then scrolling down to the end of the menu to Format. If this does not work, and you have bought a Name Brand SD card; Sandisk/Kingston/Patriot etc, return it to place of purchase with receipt, or creditcard use to purchase it, and they will replace it.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
