Gaggia Syncrony logic rapid steam leaks water from the bottom of the machine. Dispenses coffe fine, has been descaled and cleaned on the inside. Leaks water out of the bottom where the stand is, even if the water reservoir is empty.
This fix worked for me -- I will add that there is a small "snap out" plate behind the brew group that should be removed in order to access the small reservoir area -- mine was clogged with grounds. Funny, but my old Gaggia Syncrony lasted 7 years before the heating element died and I never had that issue with it. However, I did not use the coffee bypass with that one either
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
